Unlucking code for nokia phones
SOURCE: cant unluck my Nokia phone
Hi could you please give me more info so i can help you firther.
do you mean: A your phone is asking for security code when you switch it on.
B you need to unlock your phone so you can put a sim card in from netwrok your phone dont accept.
If its A then dont try entering any codes by trying to guess the right one because if you put the wrong code in more than 5 times then the phone becomes hard locked and then you will have to buy flash lead and unlocking software as no phone shop will do it for as its illegal in case it has been stolen.
If its B then the problem is that certain nokias have new software installed that stops you unlocking the phone by entering any code and the lead and sofware would be the only way of doing this.
So please let me know the exact problem
If its A then i need your imei number located on back of phone under battery and looks like 12345/12345/12345 its 15 numbers long.
If its be then i need this info :
1 model
2 imei number
3 what network the phone is on now
4 what country your in
If its possible to do using codes then i can use the sofware i have to get the codes you need but i need the info above if its A then all i need is imei but B is more difficult and i need the info listed ok
Let me know then i can assist you further ok
SOURCE: how to unluck security codes on nokia CDMA phones
default security code for all nokia phones must be 12345. you cannnot unlock security code. unless the phone is flashed. update the phone software can fix ur issue
the default code is if youyr mobile is NOkia then it is 12345
SOURCE: HI, I NEED AN UNLOCKING CODE FOR NOKIA 5300 XPRESS
Hi
You will have no choice but to pay to get your phone unlocked as it needs to be done by code or software. You will not be able to unlock your phone for free using the free Nokia calculatord. Don't even try it because you will hardlock your phone.
David
CellUnlock.net
