below is the owners Manuel but i am not sure this will help technically you need to take it to a shop for more info
since you have described the reason for your question or the issue your having trouble with. next time give more details so we can help you better. Technics SA AX6 Operating Instructions Manual
Seems like your ear piece is faulty. Some times, clearing the contacts of that earpiece speaker fixes the problem. But that requires a sort of higher level technical assistance. You better hand it over to a repair shop
it can be repaired or replaced if the boards are still available
Take it to an authorized service to have it repaired and failing that some shops that repair micro wave ovens have the technical ability to repair items of this nature
may be a good radio technician or radio repair shop could also do the repair as it is basically an electronic ( wireless/radio) that is controlled by keys
There is not enough information here to solve your problem but I can give you some places to start. Check your Mic something as simple as a broken ground wire could cause this. A quick check to see if the s meter is moving with signals could tell you if you have signal coming into the radio. Try another mic do some further diagnostics or seek professional help. There should be a CB shop around near you if not look for one at a truck stop.
You may have ant. trouble if the SWR is hi
that feeds power back into the radio and
could damage it,lets hope not start with a
good ant.and maybe the radios are not hurt
to bad.
Good Luck
send it to me for repair. it has a bad soldr joint somewhere it is a common problem on all galaxy radios. 40.00 plus 10 return shipping. i have an internet cb shop so you can watch me fix it. email me at [email protected] if you want it fixed
sub should work as long as u don't have the reciver on digital it should still work ur mains and the sub but no sound from the rears, the radio cuting out could because bye a resister failing it might not have burnt out yet but it is not working proprely if it only happens when the radios is on try to see if local stations come in clear with no antena . but if it happens when the reciver is on tv or another input take to ur closest repair shop to be fix or u might fry the mother board happen to one oif my old recivers.
