I CAN´T USE THE YOUTUBE ON MY IPHONE, IT SHOW'S THE AVAILABLE VIDEOS BUT THEY DO NOT SHOW LENGTH TIME AND WHEN I PRESS THE VIDEO IT SHOW'S THE MESSAGE "YOUTUBE VIDEOS REQUIRE AN EDGE OR WI-FI CONECTION"
Sounds like you may be out of an area that isn't getting a signal, try it when connected to wifi! Also if it is jail broken, one version of software early on caused utube to not work. Hope this helps. Merry Christmas!
This guide will show you how to make iPhone ringtones using songs on your iTunes music library right from your Windows PC without installing any application (except for iTunes, of course) and without registering to any website or any premium text services. That means, everything is FREE!
Everything is done directly on your computer, you can do this even without internet connection.
This is for all iPhones (iPhone 4, 3GS, 3G or older) and for all iOS versions.
Here's what you need:
Computer running on Windows 7, Vista or XP with iTunes installed
Song(s) on your iTunes music library
Note: You don't need your iPhone yet until you're done making your ringtone and are ready to sync.
If you don't see the Ringtones list on your sidebar, don't worry. It will show up after you're successful in creating your first one.
Procedures:
Open iTunes (from your PC) and select any song from your music library.
Right-click on your chosen song then click on Get Info.
Click on the Options tab, at the top of info window.
Look for Start Time and Stop Time, and copy whatever is written in the Stop Time box (which is the full length of the song) to avoid messing up the original copy, coz you're gonna need to put it back later.On the video, the original length of my song is 5:48.055, but ringtones for iPhones could not comprise the full length of the song, it must only be around 1 to 30 seconds (though I'm not sure if 30+ sec will still work).
Shorten the song to acceptable limit (1 to 30 sec.).On the video I used the first 9 seconds, by changing only the Stop Time from 5:48.055 to 0:09.000.You may also choose the middle part of any song, say you can set the Start Time at 1:23.456 (or any time of your choice) and the Stop Time at 1:54.321 (or any time of your choice).
Click on OK to apply the changes.
Select the same song, click on Advanced from the Menu bar at the top of iTunes Window, then click on Create AAC version.Notice that the AAC version has shorter time than the original one.
Modify the original copy back to its full length (noted on step 4), then click on OK.
Right-click on the AAC version, then click on Show in Windows Explorer. A folder will open showing your two songs in file form, the original copy having the .mp3 file extension, and AAC version with .m4a.If you cannot see the file extensions, Go to Control Panel>Folder Options>View (tab)> and from there, remove the check beside the option saying Hide extensions for known file types. Click on OK to apply the changes. (Watch the video for clearer instruction.)
Change the .m4a file extension to .m4r.You may also change the name, but that's up to you. The important thing is to change the file extension.
Then Windows will ask:Just click on Yes.
Double-click on the modified file to add it to your ringtones list, and you're done!
The only thing you need to do now is to sync ringtones so you can use them on your iPhone.
WARNING-BEFORE YOU SYNC Syncing ringtones will affect the music library on the iPhone, so before you click the sync button, be sure to transfer all your purchased songs first (from iPhone to PC) so no song will be deleted. Or better yet, do this only when you're working on the computer where: you save all your songs, or; you regularly sync your iPhone.
Notes: This guide is intended only for iPhone users, because iPhones do not accept file types other than .m4r as ringtones.
This guide is intended only for Windows users. The guide for Mac users is written separately, with its own video.
Ever had to restore your iPod touch or iPhone? Has your YouTube app showed the message "Cannot Connect To Youtube?" Well, Lucky For You I Have Two Solutions.
Solution #1: Jailbroken iPod Touch/iPhone
1. Open Cydia/Rock 2. Go to sources page 3. Press Edit 4. Press Add 5. Type : http://fishbone.ge 6. Press Ok 7. Wait for Sources to Refresh 8. Enter Search Function 9. Search for "PushFix" install the Pushfix's in increasing order (e.g 1,2,3) 10. Restart iPhone/iPod 11. Done
Solution #2 (Non Jailbroken)
1. Enter Settings 2. Enter General 3. Enter Date/Time 4. Correct Time Zone settings 5. Correct time, day and YEAR 6. HOLD Home + Wake/.Sleep Button 7. Wait for iPhone/iPod to Restart 8. Your Good To Go
Try restoring the firmware. Is your iphone jailbroken? If it is, there might be a tweak you recently installed that could be the problem. Undo the tweak, reboot, and check youtube.
Turn the iphone off, hold the menu button, now plug in the usb cord that is connected to the computer. Keep holding the menu button until a dock connector appears on the screen. You're now in recovery mode and should be able to restore your iPhone. If that doesn't work you may have a broken logic board. Here is an iPhone Repair Guide that shows how to open an iPhone. Boards are easily available on Ebay. If you want somebody else to do it for you go to iPad Repair
