Side by side fridge not freezing meats on freezer. Blows cold air but meats are not freezing. The other side of fridge not cold enough either. Cleaned dust underneath on both front & back, unplugged overnight it started blowing cold air on both sides for a couple of days but now it's back to not getting cold enough to freeze meat in the freezer & other side not getting cold either.
I was writing a big note here before then hit the wrong button, it was just a bunch of jargon anyway. Yes it is the condenser fan motor causing your problems. Doesn't cool the refrigerant properly than nothing works. I would change the fan before it causes any damage to the compressor.
Thank you very much Colin. Do you think it would be good to change the start relay and motherboard also? I already bought the condenser fan motor today and will install it tomorrow morning. I will post an update a few days after. I just wanted to be sure the fridge will run without fail cuz I had just gone grocery shopping for two weeks worth of food when it broke down and I had to throw everything out :(
SOURCE: frigidaire PLHS267ZDB2--Not cold enough
Replaced the fan and the damn thing works like a charm....Thanks alot for all your suggestions.This is a cool site and you guys are doing a great great job! Keep up the good work!
SOURCE: side by side w/ dipenser ge refridgerator
Your unit is under charge and need to check for leak. Please call qualified technician.
SOURCE: Fridge side not cooling, Freezer side is....
(After trying FixYa and paying for the premium service -- during which error codes were not even discussed) I called a service tech. Turns out it was the fan above the fridge side (which explains why the freezer was still working fine) that was "humming" but not always spinning. A quck swap of the fan and we were back in business.
FYI -- The SubZero tech said it was very uncommon for the fans to go bad.
SOURCE: ge side by side not cold enough in fridge or freezer
the fan behind the freezer panel inside
SOURCE: kitchenaid side by side too cold. Freezes everything.
the damper motor on the refrigerator portion is not working properly
It's an old whirlpool side by side that was given to me so I have no clue how old it is either. It's model number is ED25DQXVP02. I noticed the condenser fan motor in the bottom back of the fridge isn't working [I do know it stops and starts but I never saw it turn on] so I unplugged then fridge overnight and started to buy a new condenser fan motor only to have my niece phone me to tell me that the fridge seem to be working normally blowing cold air on both sides (I did plugged the unit before heading out). So I hung on the the new motor I purchased and decided to return it since the fridge seem to be working (I left a bottle of water in it to test and it froze). Today my niece told me she put a little pint of ice cream in the fridge last night and it was all melted when she opened it so I guess I'm back to square one. The compressor seem to be running fine but every time I look to check the fan is never running. I kind of give it a push then it would work then it stops and I have to give it a push again. I'm wondering if that's the part I need to replace or could it be the control board or the start relay? Any help or advice would be greatly appreciated.
I wouldn't worry too much about the board or relays, the chances of them being part of the problem are pretty slim, I think in my experience 99% of the time it is the obvious answer which would be the fan motor. Good luck
