Generator will not supply electricity
First check the circuit breakers if there ok the problem is inside like over heated parts
what heated parts would you be talking about
internal parts like the rotor and main coil check for voltage to the regulator
I have the same issue what was your resolution?
SOURCE: Problem with a kipor 12 ta generator
I just guessing here but it could mean that the oil pressure is too low.
I'd check the oil level first, then look for the oil pressure switch and temporarily disconnect it.
Regards,
Carl
when i was using the generator everything was running well and then the overload indicator light went on and it was no longer supplying electricity but the engine was still running ok. It has not been supplying electricity ever since
