Camera say busy now It want take a picture at all. I have check and the batery is charge and the memory card is not full.
Could be what you have the camera set at for how long the picture stays on the screen after it is taken. If the picture is still on the screen it wont take a picture until that picture has been stopped being shown. On my canon I have it at 2 seconds and I know at 4 it wouldn't let me take another shot so quick. Check all of your settings and read the manual.
SOURCE: memory card is full but there are no pictures on my camera.
Try using the "format" option in your camera's menu. That should wipe the card clean. There's probably a file or folder that the camera can't recognize as being one it created. You might also plug the card into a card reader and open it on a computer. The format option on the computer will also wipe the card clean to start fresh in the camera.
SOURCE: Camera says "Memory Card Full" but the card is empty...
Hi, First, lets try formatting the card. But be aware that it will erase everything on the card. 1 Turn on the camera 2 Press the Menu button 3 Toggle once to the left to get the Setup menu (the one with the hammer/wrench icon) 4 Toggle down to Format 5 Select OK and press the Set button. To perform a low-level format, press the up arrow and then the right arrow to add the check mark. After you do this, exit the menu by pressing the Menu button. Take some still photos first. Download them to the computer but don't delete them from the card yet. Disconnect the camera from the computer (or if you are using a card reader remove the card). Delete the images from the card by using the menu in the playback/review mode. Let me know if this solves anything.
SOURCE: New San Disk memory card not working
vebhat,
Make sure the little slide on the SD card is in the right position, and if it's a high capacity SD it might not be compatible with your camera...
randy320sgi
SOURCE: Conon 350d constant 'busy' message...
Is the memory card locked? Is it bad? Are you using internal memory? First, see if the lock switch is on. Then try putting it in a memory card reader.
SOURCE: memory card capacity for my older canon digital camera
Does you camera use CF cards?
If so the may work but some of the newer high tech CF cards are made for newer cameras.
It may be worth a shot to try the 2GB card and if it does not work, sell to someone who uses those.
