When I push play on the CH-DVD 300 DVD Player I get a box labeled CD menu beneath it says ROOT then under that MODE adjacent to that I have ROOT highlighted and under that it say Folder normal. It will not let me play the DVD.
SOURCE: Reset Cyberhome CH-DVD 300
Dear friend,
Press and hold STOP button on front panel of the player more than 5 sec. The player reset after 5 sec.
SOURCE: Cyberhome 300 DVD Player: pal to ntsc mode?
Turn on your dvd player then press continuesly the stop buttom in the panel 10-15 seconds til the screen appears.
SOURCE: Cyberhome Ch- DVD 300
Your advice was very helpful. After two+ months of tooling around and navigating around the menu blind I was on the brink of trashing it.
At first I tried the stop button with a dvd in the player with no success. After taking the dvd out, turning in off/on then pressing the stop button for 20 seconds the screen turned blue as said.
This help saved me a great amount of fustation.
Thank You!
SOURCE: My Cyberhome CH-DVD 300 MU BIOS: VOE won't turn on.
I had EXACTLY this problem. Fuse is OK. LED barely looks like its glowing.
Take six screws off cover, remove cover.
Inside, look at the power supply board. There will be a 2200 uF capacitor, probably rated at 10V. It's about an inch long and 3/8 of an inch in diameter. If it it bulging slightly at the top, it needs to be replaced.
Take two screws off power supply board, There are also two plastic standoffs holding the board on, it's best to squeeze those with a needlenose pliers to release the board.
I replaced the cap with another 2200 uF, but rated at 16V. Now the player works again.
SOURCE: Cyberhome CH-DVD 300 DVD Player says loading and
Insert the DVD into the tray and does not read
