I push the rewind button and slide the lever to the left as usual; it starts to make the rewind sound then stops. It's not a dead battery; I've tried that. Film is stuck in camera.
SOURCE: Film advance lever and shutter release button are "stuck"
No, it is not the battery. My guess is that the film leader did not stay in the take-up spool and is now bunched up around it. Try rewinding the film carefully as you normally would but remember that you are only rewinding a small portion of the length. You can even just open the film door and start over. You will only loose 3 or 4 frames on the roll.
SOURCE: Nikon N75 - error message, nothing working.
You have to reset the rewind counter by pushing the two buttons simultaneously - one on the side of the lens mount, the other by the release button - red, cassette symbols. This tells the camera there's no film in it.
SOURCE: location of rewind pin for nikon n6006 film camera
There is a safety switch to prevent accidental operation. Hold the camera like you are taking a photo. Rotate the camera down so the lense is pointing towards the floor and you are now looking at the bottom of the camera. On the right is a small button. In the middle is a slide switch with an arrow pointing to the left. You need to hold in the button on the right while sliding the switch to the left.
SOURCE: FILM WILL NOT REWIND
On the N80 - there are custom functions you can set in terms of when a film rewinds. Normally it is default to rewinding automatically at the end of a film. If this setting has been changed, or you want to rewind a film before the end - you need to press two buttons and hold them, at the same time.
The first button is the LCD backlight button next to the LCD, and the second is the flash sync button on the rear of the camera. Both should have a little red film symbol on them. Press them both and hold them, and the film should begin to rewind.
SOURCE: my nikon fm10 film advance lever is stuck, i can't
You may end up sacrificing the used film or you can rewind it early.
I have had it happen that the film sprocket holes had striped out causing the advance sprocket to get out of sync with the film making it ride up onto the area between sprockets and creating a jam.
If you can, rewind the film onto the feed roll to preserve the exposed portion and then remove it from the camera.
Try the film advance then with an empty camera, releasing the shutter and repeating the cycle to determine if the advance mechanism will now act as it should; if it does, then the film was probably at fault and it may never happen again.
If you cannot respool the film, I would take it to a professional photo lab and have them unload the camera in a dark room if you want to try to save the pictures already on it.
