Question about Kenmore 24902 Top Load Washer
Kenmore series 80 washer only works on heavy duty cycle.
My washer overflowed (I had the level switch between tow settings).
Now it works , but only on the heavy duty cycle. When I try on the other duty cycles when it starts on the agitate proton of the cycle it starts to agitate and makes a groaning sound and then retries. I also noticed the lights dim in the laundry when it tries to agitate on anything but heavy duty.
  • Anonymous Mar 27, 2014
    drain is plugged how to unplug?
  • 640 Answers
Bad transmission,,check voltage...below 110 with load and water pressure switch or hose defective..
Posted on Dec 24, 2008
6ya staff
SOURCE:
Whirlpool heavy duty commercial washer, mod# CAM2742TQ0. Washer does not fill all the way on rinse cycle set on large load.
The service manual shows this machine as a timed water fill. When the washer is filling in rinse, is the flow strong? If not, check the screen on the water valve at the hose connection. If clogged, you can try and clean it with an old tooth brush and a spray water bottle. If not clogged, there are two water level switches. You could have an issue with the high level switch.
Jun 24, 2016 | Whirlpool Washing Machines
GE 7 cycle heavy duty washing machine overflows
Could be the water level switch is bad it cuts off the water when it gets to the correct level. Also could be the hose connected to it has came loose on either end . Could be the water valve is stuck open and can't shut off the water. Hope this helps.
May 03, 2011 | Washing Machines
Kenmore Heavy Duty 80 Series Extra Capacity Plus Model# 92480200. The washer will begin to fill and will not stop filling regardless if water level setting is on low, medium or high and will overflow and...
The problem is the pressure switch has failed or the hose is plugged up, has a hole in it. These are usually inexpensive and are very easy to replace. Here is a video this will walk you thru testing and replacing a pressure switch. You can also enter your model # for diagrams and illustrations of your specific model. All parts come with installation instructions. Not all models are available.
Oct 30, 2010 | Kenmore Washing Machines
I have a 9 year old heavy duty top load washer that keeps overflowing no matter what water level it is on. I think it might need that part. If so how do I install it?
If your washer is overfilling, check these:
Water-inlet valve
Water-level switch
Water-inlet valve A defect in the water-inlet valve may mean that it's no longer able to shut off completely when the electricity has been turned off to it. If this occurs, the valve may leak and drip water into the clothes tub. In time, the water may accumulate substantially. If this happens, you need to replace the valve.
Water-level switch A defect--or an obstruction--in the water-level switch may mean that it can't tell the water to shut off. So the machine overflows. This switch senses the water level in the clothes tub. It's usually a diaphragm device with a small, clear tube attached between the switch and the bottom of the washer's outer tub. As the water level in the tub increases, the pressure on the air in the tube increases. When the pressure reaches a certain level, it activates the switch, shuts off the water, and signals the timer to begin the agitate cycle. You can either clear any obstruction in the tube or replace the water-level switch.
Apr 01, 2009 | Frigidaire Washing Machines
Kenmore 80 series heavy duty 3 speed
This problem is generally caused by a pressure switch failure. The pressure switch controls when to shut the water inlet valve off at the appropriate level and is located behind the load level or water level selector knob on the operator console. Before assuming, however, that you have a defective switch, read the following link first:
http://www.fixya.com/support/r762094-washer_overflows
In the majority of the problems I have experienced with an overflow condition on a washer, it has been caused by the air hose coming off the pressure switch. Hopefully, this will be the case with your washer and will not require parts. I hope you find this information helpful. Let me know if you require additional assistance.
Sep 29, 2008 | Kenmore 24032\24036 Top Load Washer
Washer problem
THE SPEED SELECTOR SWITCH MAY BE SHORTED CAUSING THE MOTOR TO TRY AND RUN ON BOTH THE LOW AND HIGH SPEED WINDINGS. THIS WILL PULL TOO MUCH CURRENT AND TRIP THE BREAKER.
THE MOTOR WINDINGS FOR THE HIGH SPEED COULD BE SHORTED CAUSING EXCESSIVE CURRENT DRAW.
Apr 10, 2008 | Kenmore 22422 Top Load Washer
Fill Cycle Won't Stop
heres hteaprt numbr for both the water level switch and the connecting tube, before i replace he switch make sure the tube is connected to rear of tub nad isnot cracked or kinked, and connected correctly to the switch for that matter. a hole in the tube would hamper he switches ability to sense when unit is full
3356466 water level switch,3347780 pressure switch tube
Mar 16, 2008 | Whirlpool LSQ9030P Top Load Washer
Kenmore 24902 Top Load Washer Logo
540 people viewed this question
fordexpert
Harvey Mahal
Kristen Denison
Kristen Denison
Level 1 Expert
