The dryer comes on but it will not dry. Where can I check the fuse?
I have written a tutorial on how to troubleshoot a 90 series dryer that will not heat: http://www.johnfixesstuff.com/2015/05/how-to-fix-kenmore-90-series-gas-dryer-will-not-heat.html
First check the vent outside to see if it is blowing air out strong, then check for heat.
The
Kenmore 80 Series of dryers are consumer grade dryers for home use. As
with most home appliances, the Kenmore 80 series dryers will
occasionally not work as intended. If a problem occurs with your dryer,
however, you do not necessarily need it serviced by a technician. You
can attempt to troubleshoot and fix any problems with your dryer before
contacting a technician.
