Toshiba Portege M405-S8003 Tablet PC Logo
dingus gus Posted on Sep 08, 2012
My screen is black on my toshiba m405 tablet pc
It is a hardware issue, i have removed the battery many times and even the hard drive. I moved the screen around in all directions and it did appear once more, but now it will not work. The computer is running but no visual. Can you please tell me what needs to be replaced?
Anonymous
Level 1:
New Friend:
  • Contributor 6 Answers
  • Posted on Sep 08, 2012
Anonymous
Contributor
Level 1:
New Friend:
Answers
6
Questions
0
Helped
5994
Points
31
Well my friend...
You can just open up the frame that's in front off the screen and unplugg 2 video cables from the back of the screen and buy a new screen.It's more cheaper to do it self! This is a very good video on 'How to replace a notebook screen: http://www.youtube.com/watch?v=1eaI5aobwDU
5 Related Answers
Anonymous
  • Posted on Jun 23, 2008
SOURCE: Drivers lost for Toshiba Tecra M7 Tablet PC
download win xp sp3 and install .... ur laptop should work and then download and run the "registered" version of Driver Detective ... it should find drivers specifically for YOUR laptop ... that might work ...
Anonymous
  • Posted on Mar 25, 2009
SOURCE: Clean dust from tablet pc screen
You have to remove the screw covers (the black squares around the screen), remove the screws and gentley pry the cover open with yor finger nails or a flat head screw driver, but be careful not to dent the sides with the screw driver. You can then take a can of air and blow the dust out. I would not touch the sensetive screen under neath. You could take a anti static, micro fiber cloth to wipe off the tough stuff.
Anonymous
  • Posted on Apr 11, 2009
SOURCE: toshiba M400 tablet wont start
I've had this problem intermittently on my Toshiba M400, and it recently became bad enough that it was failing to start on most attempts, and crashing soon afterwards if I moved it. Prodding the heatsink to change its position may have helped, but this could have been due to chance. It also had a habit of resetting itself when leaning on the left side of the keyboard when typing, but not when using an external keyboard. It's always had occasional crashes under high CPU load, causing the machine to freeze and the fan to go up to maximum. BIOS updates improved this initially, but in recent months it got worse again, especially when using Virtual PC unless hardware virtualisation was disabled.
I've just stripped down the laptop using the guide suggested by thiscomputer at http://www.irisvista.com/tech/laptops/Toshiba-Portege-M400/take-apart-tablet-pc-1.htm (good find!). Many parts are more fragile than in a desktop PC, but otherwise if you're used to taking stuff apart it shouldn't be that big a deal. You'll need a normal and small crosshead screwdriver (jeweller's screwdriver set works fine) and space to lay out the screws in a pattern so you remember where they go - consider making notes.
I fixed two things that could have been a problem: Firstly, a fair amount of dust was blown away with a hairdryer and vacuumed from the heatsink. Secondly, the pink thermal grease that couples the CPU to the copper heat pipe appeared to have all squeezed off the CPU die and had accumulated around the sides, possibly due to the small freedom of movement in the heatsink being repeatedly shaken. The grease was still soft so could be scooped back onto the die with a flat-bladed screwdriver. I also bent the legs of the Y-shaped CPU-to-heatsink retaining clip so that there was a greater downward force on the CPU. I figured this would improve thermal contact, especially if the clip had naturally bent and come loose over time. Removing the CPU itself didn't show any damage, but might have improved the electrical contact when reinserted. Be careful when screwing the Y-shaped retainer back in - because of the springy nature of the legs, if the screwdriver slips the screw will fly across the room and you'll have to hunt for it :-) The other thing to note when reassembling is that the wi-fi on-off switch engages with the lug on the motherboard, if this is wrong you won't be able to move the switch and the actual state will be the opposite of the switch position.
Finally, after I reassembled it still refused to start. I noticed the DVD drive wasn't properly flush with the case, and on removing the DVD drive it started. Close inspection of the drive and laptop connectors revealed a small metal tab had come loose, and the laptop continued to work with this tab removed and the drive reinserted properly. I removed and swapped some memory modules while experimenting with the DVD drive which also had some effect - it's possible that an ill-fitting DVD drive bends the memory above it and affects the contact. It's entirely possible that this was the only problem to begin with, and that playing with the CPU made no difference, so maybe check this first! But whatever it was, happily my m400 seems to be operational again.
Anonymous
  • 7 Answers
  • Posted on May 14, 2009
SOURCE: My Toshiba M400 did not read hard drive!
You need to activate the Raid diver. This can be done by slipping it into the XP install or adding the Raid Drivers at the time of installing the operating system. See Toshiba.com support pages for a copy of the Raid drivers
Anonymous
  • 163 Answers
  • Posted on May 17, 2009
SOURCE: Tablet PC screen salvage for use as an input device?
I would look on ebay for a smashed one first.
or one with a malfunctioning screen. When I did an e-bay search for your model It came back with 509 results. The bottom link is a repair specialist for that kind of notebook.
Tecra
-M4-S435-Tablet-PC-Laptop_W0QQitemZ160335072304QQcmdZViewItemQQptZLaptops_Nov05?hash=item2554b70c30&_trksid=p3286.c0.m14&_trkparms=72%3A1234%7C66%3A2%7C65%3A12%7C39%3A1%7C240%3A1318%7C301%3A0%7C293%3A1%7C294%3A50">http://cgi.ebay.com/Toshiba-Tecra-M4-S435-Tablet-PC-Laptop_W0QQitemZ160335072304QQcmdZViewItemQQptZLaptops_Nov05?hash=item2554b70c30&_trksid=p3286.c0.m14&_trkparms=72%3A1234%7C66%3A2%7C65%3A12%7C39%3A1%7C240%3A1318%7C301%3A0%7C293%3A1%7C294%3A50
Tecra-M4-M7_W0QQitemZ260411761192QQcmdZViewItemQQptZUS_Gift_Certificates?hash=item3ca1c02228&_trksid=p3286.c0.m14&_trkparms=72%3A1234%7C66%3A2%7C65%3A12%7C39%3A1%7C240%3A1318%7C301%3A0%7C293%3A1%7C294%3A50">http://cgi.ebay.com/LCD-Repair-TOSHIBA-Tecra-M4-M7_W0QQitemZ260411761192QQcmdZViewItemQQptZUS_Gift_Certificates?hash=item3ca1c02228&_trksid=p3286.c0.m14&_trkparms=72%3A1234%7C66%3A2%7C65%3A12%7C39%3A1%7C240%3A1318%7C301%3A0%7C293%3A1%7C294%3A50
I did a Google update and installed avast software and now my computer hangs up while booting windows XP.
If you are lucky, there will be a restore point you can go back to on your computer. I expect Google update is unhappy with XP as it is an OS that is no longer supported.
Blank Screen
The bad thing about this is that it could be a software related issue or a hardware issue. If you're willing, you can disassemble the unit and check for a damaged or loose connector to the monitor. If there doesn't appear to be any issues there it may well be that the screen has gone bad or there is something wrong with the driver/setting on the unit itself that is causing the screen to saty off. I'd move forward with the hardware issue first though.
1helpful
I want to add RAM to my Toshiba Portege M405-S8003 but I can't find the memory slot. The only things I see underneath my laptop are the battery pack, a square-shaped slot (when I opened it, there's a paper...
Hi,the Ram slot you are looking for is underneath the keyboard,if you have expertise on uncoupling and re-coupling a system then proceed,if not take to a qualified technician to that for you wont take any time.
2helpful
2answers
Fresh vista install won't take and laptop acts all goofy
seems like a hardware problem...Hard Disk Probably.but don't take chances...first remove any external hardware attached [usb,printer etc.remove the battery also]then try to install the OS use another CD or you can even use Windows XP.Make sure you change the SATA setting in the BIOS for XP. You did not mention the error message or when does it hangs while installing Vista.Try changing the Hard Disk.If there's still problem then it's your motherboard. As far as overheating is concerned you need to see how long does it remain powered on.And when you switch it on again does it turns off quicker than before. Take it to the service center.
Hardrive won't run, screen is black
Most possible one of your Toshiba Tecra m4 driver is not working properly, but don't worry give me a call at +1 (833) 493-0111 so that i can suggest you the right way to fix it!
2helpful
Black screen at power on
I had the same problem. I pull of battery and then immediately reattached and ta-daaaa! Windows came right up!
Hope this helps!
gg
2helpful
4answers
Toshiba M400 tablet wont start
hello jpmca
try to take off your fan cable
here http://slashstar.com/blogs/alex/archive/2006/09/30/Toshiba-M400-Fan-Hack.aspx
and try to release the memory sodimm, release the battery and plugin the power cord again
if problem solve try to updated your bios for fan noise solution
here
http://support.toshiba-tro.de/kb0/TSB6A01KJ0000R01.htm
oke
cropp
Top Toshiba Tablets & eReaders Experts
k24674
ExpressFiX
ExpressFiX
Grand Canyon Tech
Grand Canyon Tech
Are you a Toshiba Tablet and eReader Expert? Answer questions, earn points and help others
