My printer won't print and I do not know how to fix the problem. There is a blinking light and an E on the screen.
SOURCE: can not print from computer to printer
hi,
try the following:
> start-->run, type services.msc
> double click on print spooler and click on stop and then click on start. press ok and close all the windows.
> unplug the usb cable from the printer
> now go to control panel and open printers and faxes.
> right click and delete all the printer icons related to hp deskjet f300 series.
> now plug the usb cable back to the printer
> wait for few minutes while it installs the driver automatically.
> thats it... now try printing
thanks and regards
agnel
SOURCE: Continous Red light blinking on the printer causing it not to print
plz check the ink cartridge status
SOURCE: Printer is not printing but power light is blinking
You have a faulty ink cartridges. Try cleaning the contact points including on the carriage.
SOURCE: I cannot get my F340 to scan. When i push the
Are you using Vista? I know that the Scan button doesn't work with Vista. There's a way around it though (if Vista is the problem.) Click the Windows Vista icon, click All Programs, and then click Windows Photo Gallery (mine was in a subfolder.) Click File, and then click Import From Camera or Scanner. Click Import, and then click Scan. There is also a similar way to scan with the Paint program.
SOURCE: blinking/flashing lights(orange & green) &
that is because ur head of ur printing cartridge is damaged.
remove ur cartridges black as well as color
n install only black cartridge n check d blinking of lights on ur printer if it doesn't blinks it's mean ur black cartridge is OK but ur blinking of light on ur printer is same it's mean ur head of black cartridge is damaged
after this process remove the black one cartridge and install the color one cartridge n check d blinking of lights on ur printer if it doesn't blinks it's mean ur color cartridge is OK but ur blinking of light on ur printer is same it's mean ur head of color cartridge is damaged
now take a dry cotton cloth n gently clean ur cartridges head
install both cartridges on ur printer n check ur blinking light on ur printer
that will work only if u r too lucky other wise u have to purchase a one cartridge.
If
you need more help come back.
Post
/ thumbs / testimonial are welcome!
go to Start, Settings, Control panel, printers and faxes is your printer there? is there a checkmark? no, then right click and set as default, put your mouse over it does it say Ready? no, then change cable.
send test page, it should print, if not the USB or Parrallel input of your printer has a problem.
