Question about LG GSA 4163B DVD±RW Dual Layer Burner
Hl-dt-st dvdram gsa-t40n ata device driver curupted
Cd/dvd drive will open, but computer does not reconize it
  • 28 more comments
  • farambrown Dec 30, 2008
    Will not run any of my disks, in system properties says the driver could not be loaded
  • Anonymous Jan 05, 2009
    same problem :(
  • osomandf Jan 06, 2009
    the same problem (code 39)
  • Anonymous Jan 11, 2009
    error 39 medion PC after the instalation of digital TV receiver.
    I don´t know the solution
  • rod_and_ang Jan 13, 2009
    plzs plzs help
  • smallekin Jan 15, 2009
    computer can not recognize
  • Anonymous Jan 18, 2009
    i have the same problem
  • Anonymous Jan 20, 2009
    the drive may be corrupted or missing.
  • samovic Jan 23, 2009
    cd/dvd drive will open, but computer does not recognize it & also I make uninstall for it & try to make a new installation but i can not.
  • Scooterloon Jan 24, 2009
    Device manager stating driver software corrupted (code 39), any solutions out there?
  • Anonymous Jan 24, 2009
    kak
  • Anonymous Jan 27, 2009
    tried deleting file but it didn't work
  • Anonymous Feb 07, 2009
    It is installed but my computer all of a sudden doesnt recognize the device. It says the drivers are all up to date.
  • sanbru1 Feb 12, 2009
    Cant read disks......and in device manager says that the drive status is "Windows cannot load the device driver for this hardware. The driver may be corrupted or missing. (Code 39)"
    Cant read disks and in device manager it says the status is "Windows cannot load the device driver for this hardware. The driver may be corrupted or missing. (Code 39) "
  • Anonymous Feb 17, 2009
    Same problem as everyone else
  • Anonymous Feb 20, 2009
    I can see it in the "enhetsbehandling"= I don't know what it is in english.
    It says that the driver might be damaged or is missing, so i updated the driver, but still, it won't work!
  • Anonymous Mar 04, 2009
    tidak bisa detect dvd rw
  • Anonymous Mar 06, 2009
    driver tida terdeteksi...
  • Anonymous Mar 13, 2009
    IT KEEPS TELLING ME THE DRIVERS MAY BE CORRUPTED. AND IT WONT READ ANY DISCS.
  • Anonymous Mar 18, 2009
    HL-DT-ST DVDRAM GSA-T40N ATA Device, i get code 39, can you help pls? windows says my driver is up to date
  • Nicoz Mar 19, 2009
    window can not start this hardware device because its configuration information is incomplete or missing
  • Anonymous Mar 19, 2009
    great job mkpelletier...you solved it!!!!
  • sergey21 Mar 20, 2009
    HL-DT-ST DVDRAM GSA-T40N drive - is reading CD only when she want
  • Anonymous Apr 11, 2009
    When I load a disk nothing happens and what used to be my E: drive is not showing - just C drive and D drive
  • Anonymous May 14, 2009
    Look at the best solution, it works :D
    Thanks to mkpelletier
    Thanks a lot
  • m_chooramun May 20, 2009
    my gsa t40n cannot change region as it come to the limit, {4D36E965-E325-11CE-BFC1-08002BE10318} does not have the upperfilter key!
    what should i do?
  • Anonymous May 21, 2009
    el codigo 39 no responde
  • AHMED_HI May 25, 2009
    THE DEVICE NOT APPEAR IN MY COMPUTER
  • Anonymous May 11, 2010
    Do you have it properly connected? If this is a serial ATA then you would not connect a ribbon cable. Just the ATA power and data cables. Hope this helps.
Problem occurs when vista registry entry is corrupted. The steps to resolve this are as follows:
  • run regedit.exe
  • navigate to HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\Class\{4D36E965-E325-11CE-BFC1-08002BE10318}
  • Depending on your particular setup, you may have multiple entries for {4D36E965-E325-11CE-BFC1-08002BE10318}. If this is the case, find the one that says DVD/CD-ROM drives (under default)
  • Once you have found the appropriate key, you will see an entry that says UpperFilters.
  • Delete this key and then restart
  • (NB: Do not delete any other 'UpperFilters' key that is not in the category of DVD/CD-ROM drives, otherwise you may get the BSOD.)
This solution fixed my problem.
Posted on Jan 27, 2009
  • 1 more comment
  • richardstani Sep 24, 2010
    Straightforward and clearly noted first line DVD CD ROM on the relevant registry entry. Thanks.
  • am1407 Dec 04, 2010
    Bravo mkpelletier.
    Il est vrai que le "LOWER filters" doit être également enlevé de la base de registre comme il est dit par "Leila Mosh".
    Information parfaitement décrite, sans aucune erreur, ce qui permet à monsieur tout le monde de faire cette manipulation.
    A noter:, mon lecteur externe USB est également réapparu dès que les 2 clefs ont été supprimées.
    Bravo encore et merci beaucoup.
    am1407
  • sriman Jan 10, 2011
    Hello mkpelletier
Cd/dvd driver will open, but computer does not reconize it ,error code 39 comes up
Posted on Jan 03, 2009
Mkpelletier--great advice!! I called toshiba though, because it still did not fix the problem. Found out from Toshiba that not only do you need to delete the upperfilters but the LOWER filters as well. Otherwise, these instructions are perfect!!
great job mkpelletier!!
Posted on Mar 25, 2009
    Hello, I had deleted upper filters key from the registry but it recreates after reboot and the lower filters key is not find any where. please tell me the location of lower filters key and suggest me a solution for the same problem. My DVD RAM is HL-DT-ST DVDRAM GSA-T40N
    President:
  • 1,257 Answers
Follow this article to fix the issue.100% Guaranteed
http://social.technet.microsoft.com/forums/en-US/itprovistahardware/thread/bd9763de-6141-45ea-990b-70c207fe3fb6
Posted on Mar 22, 2009
  • Deeps . Jun 27, 2009
    Normal
    0
    false
    false
    false
    MicrosoftInternetExplorer4
    /* Style Definitions */
    table.MsoNormalTable
    {mso-style-name:"Table Normal";
    mso-tstyle-rowband-size:0;
    mso-tstyle-colband-size:0;
    mso-style-noshow:yes;
    mso-style-parent:"";
    mso-padding-alt:0in 5.4pt 0in 5.4pt;
    mso-para-margin:0in;
    mso-para-margin-bottom:.0001pt;
    mso-pagination:widow-orphan;
    font-size:10.0pt;
    font-family:"Times New Roman";
    mso-ansi-language:#0400;
    mso-fareast-language:#0400;
    mso-bidi-language:#0400;}
    issue..
    http://www.windowsguru.org/solutions.htm...
Do what mkpelletier said with the registry values except delete not only the upperfilter registry but the lowerfilter one as well and reboot, it should work
Posted on Mar 19, 2009
    New Friend:
I have had am e-machines E510 for almost 1 year and the CD/DVD rom drive (as above) stopped working after 3 months! I used the solution given by MKpelletier and now working perfectly thankyou so much :-)
Posted on Nov 09, 2009
Awesome...i tried everything.....great job mkpelletier...you solved it!!!!
Posted on Feb 05, 2009
HKEY LOKAL MASHINE DO IT
Posted on Jul 14, 2009
    New Friend:
Hello everyone, i spent too much time looking solutions for this problem and finally i came up with the solution of unplugging the dvd unit and plug it back in and voila! that simple process fixed it all!
I hope it works for you too!
greetings from Mexico
Posted on Jan 22, 2011
    New Friend:
I don't have a solution, but I HAVE TO SAY THANK YOU TO mpelletier. I've had this problem with this computer for SIX MONTHS. I even bought a new laptop last month out of disgust, but thought I'd give it one more try today. His solution worked perfectly!! Thanks mpelletier - you should have a website of your own, and when you do, come back here and let us know!!!!!!!!!
Posted on Mar 14, 2010
    New Friend:
In the directory you said i have DIGITAL AUDIO stuff =S i can't find DVD/CD-Rom Directory =( I have Win XP sp2 Acer Aspire 5312
Posted on Mar 12, 2010
6ya staff
SOURCE:
Hl-dt-st dvdram gsa-t40n driver
Windows XP and Vista and 7 contain the necessary device-drivers to read from any CD/DVD drive.
So, what is your _real_ problem ?
Nov 27, 2010 | Computers & Internet
My A205-S5855 would not boot. I used RECOVERY disks and got system up and running...BUT now the A205-5855 will not recognize the HL-DT-ST DVDRAM GSA-T20F ATA Device (DVD-CD Drive). I reinstalled drivers...
Sad news when ANY company SELLS SYSTEMS but offers such poor driver support!
TRY this YOUTUBE link:
Solution HL DT ST DVDRAM GSA T20N ATA CD DVD device has disappeared
Also be sure to check the other links offered at that address too... in the TEXT replies.
Hope this helps!
Anthony
Nov 26, 2017 | Toshiba Computers & Internet
HL-DT-ST DVDRAM GSA-T20L ATA Device cannot read DVD
first of all check that ur laptop is not infected by viruses,because sometimes it happens due to virus...
make sure that the DVD you r trying to run is scratch free....ans is clean...
Sep 12, 2009 | Computers & Internet
Dvd driver noy found
There is a Microsoft KB article on this subject. Here is the link :
http://support.microsoft.com/kb/314060
Just follow the instructions and it may solve your problem
Jun 09, 2009 | Computers & Internet
Help can my dvd writer burn dual layer dvd's ??
http://reviews.cnet.com/dvd-drives/lg-gsa-t40n-super/4507-3212_7-33125331.html?tag=mncol;psum
supports both dvd+r dl dvd -r dl
Apr 23, 2009 | Fujitsu Siemens Computers & Internet
I need firmware for HL-DT-ST DVDRAM GSA-T20L ATA
I have the same problem and after two months (I'm a total beginner), I finally stumbled on this site.. check it out and if you can help me I would appreciate it. I downloaded the update, but I can't figure out what to do with it to make it work. I hope it helps.
Tony
http://h20239.www2.hp.com/techcenter/lightscribe/index.htm
Jan 07, 2009 | Computers & Internet
LG GSA 4163B DVD±RW Dual Layer Burner Logo
42,599 people viewed this question
Top LG Computers & Internet Experts
Ekse
Alun Cox
k24674
Are you a LG Computer and Internet Expert? Answer questions, earn points and help others
