Where are the ram sticks located? How do I get at them?
Http://www.youtube.com/watch?v=crM27ICi8Ao
watch the video might although not be the same laptop
it is an asus x53e series
hope it helps
SOURCE: memory slots?
I found the solution to roger2 and my own problem. The secondary memory add-on slot is on the bottom of the unit, and can be accessed by removing one screw and the slot cover. The other, main memory slot is actually located underneath the keyboard. You should shut down the computer completely, unplug the power plug, and also remove the laptop battery before installing memory. Also, it may void your warranty if you mess around inside of your laptop, so please keep this in mind. You will need to take a very thin flat head screwdriver to gently pry up the panel above the F1-F12 keys. The panel is the entire plastic piece covering the speakers that has the power on, play, stop, ff, rw buttons on it. I used a very thin and flat hair clip that I found laying around to pry up the edges starting from the Pause/Break key moving left towards the ESC key. The screen lid has to be opened all the way for the piece to be completely removed. Once that is taken off, you will see two small screws holding the keyboard in place. Remove these two screws and gently pull out the thin ribbon cable connecting the keyboard to the laptop. The ribbon cable is located directly underneath the spacebar, so move slowly and carefully when removing the keyboard so as not to damage anything. In the center of the exposed area, there is a sort of rectangular metal cover with two screws holding it in place. The one that is about the same size as the slot cover on the other memory slot is the correct one. Remove the screws and open the metal cover. Underneath is the other memory slot. After you install the other memory stick, if you have 4 GB of total RAM, you should know that in 32-bit operating systems, Windows will only be able to use approximately 3.0-3.5GB of RAM. This is because of a limitation of 32 Bit Windows operating systems, and not because of the RAM itself. Only 64-bit operating systems will be able to use all 4 GB. On my system for example, I have the same Toshiba M105-S3041 laptop as you do, running Windows XP Home with two 2 GB sticks, and My Computer properties shows that I have 2.99 GB memory.
SOURCE: IBM T30 RAM memory module only 1/2 working?
The problem is the mother board. One of the memory slots has gone bad. This is common with T30s.
SOURCE: error message after installing memory ram upgrade.....
Your memory appears compatible with your model of laptop. It is possible that you have a bad stick of memory. Try installing the sticks 1 at a time and boot up with each stick separately and see what happens. If 1 of the sticks allows you to boot but the other does not then I would contact PNY for a replacement stick. Just to double check here you are installing 2 gigs total not 2 2gig sticks for a total of 4 gigs. Max memory for Dell Inspiron laptops is 2 Gigs.
SOURCE: ASUS Ram Location
look in the manual on page 16.shows where its located.
http://dlcdnet.asus.com/pub/ASUS/nb/A2H/e1309_a2_hw.pdf
SOURCE: trying to upgrade memory in a toshiba satellite a105 s1013
Pls Check this link, in reference to your memory upgrade...it seems that your laptop could only accomodate max 1Gb of RAM
http://support.gateway.com/s/Mobile/Q106/Magic/5948sp2.shtml
