Model-JWTS-10
You can download the manual from this site
www2.woodcraft.com/pdf/708100.pdf
SOURCE: How do you align the motor on an older (JET)
Remove the drive belt, loosen the motor base bolts on the motor and put a straight edge on the outside edge motor pully rotate the motor till the straight edge lines up with the outside edge of the saw blade pully then retighten the motor base bolts and replace the drive belt.
This is a 10" contractors table saw mfg. in 1995, model no# JWTS-10 . Stock no# 708471,i can't find the owners manual pfd. on the Jet web site,(perhaps because of the age of the saw). Nothing is wrong with the saw, i'd just like a manual. I just recently bought it used .
Thank you ,Dennis for the pdf. link @ woodcraft. But sadly this is the newer version of this saw (it's motor is inside under the table) my saw has the motor mounted outside the rear of the saw. But thanks for you're post.
Mike, I too, am looking for a manual as I am having probs with belt size. Jet USA was no help unfortunately, so any info you have gathered would be appreciated
