I have a Sharp BD-HP21X Blu-ray Disc player that is independently connected to a Sharp Aquos 42D85X tv via a HDMI cable. The player plays dvds fine, as well as jpeg cds, but will not play blu-ray discs. The message "Incompatible Disc" appears when I load a disc. I've tried 4 different blu-ray discs, all brand new, all spotless. I've checked the playback settings, entered a pin code and set to Australia and No Limit for playback but no success. I reset to factory settings and tried again, no luck again. One disc played for a couple of minutes then froze. All discs including the one that froze have the Incompatible message. Please help.
I had the exact same problem as you did... I bought the Sharp Aquos 42D85X which came with Sharp BD-HP21X Blu-ray Disc player. could not get brand new blu-ray movies to play and i found it froze everytime after 10 secs. I phoned sharp who basically were no help watsoever! I then went and returned my blu-ray movies back to the store thinking it was a problem with the discs.. The people there were extremely nice and since they had a display model of the BD-HP21X instore they offered to test the movie on it to veroify whether it was the blu-ray player was the problem or not. Turns out its a fault with all of the BD-HP21X models. So we then ended up returning it back to the store we bought it and exchanged it with the older model (BD-HP20X). I now have no problems playing blu-ray movies. Although another suggestion is to perhaps download the lastest firmware update & see if that resolves your issues.
There are two reasons that cause this issue:
1. Your disc player need an update. Just go to the official page of this software, and then download the latest firmware to a flash drive. Then, plug it into your disc player to update your Blu-ray player. Normally, you will find a USB port on the back.
2. The region code of your Blu-ray disc doesn't match the region code of your player. In this case, you need a Blu-ray region code remover. Here Leawo Blu-ray Copy will be recommended. It offers you the best solution to copy Blu-ray/DVD movie and remove region code and copy protection without quality loss.
Where can I find this firmare update
