My washing machine makes really loud noises when spinning. It is still working but the noises are getting worse. Started out only occasionally now every time it spins the noise increases.
SOURCE: Kenmore Oasis Washing machine makes noise during Spin cycle
with the machine empty see if you can lift up only the tub and see if it drops down.check to make sure there is nothing between the tub and outer tub have you gotten an f-51 error?
SOURCE: Very Noisy Operation
you will have to access the bottom of the agitator from the back of the machine. Either you have loose bolts or else you agitator bearings are shot
SOURCE: Spin Cycle won't work, loud noise
It appears your clutch assembly has failed in this instance.
For replacement parts - head on over to PartSelect.com or RepairClinic.com and enter in your full model number for a full parts listing.
I recommend both sites because ...
FixYa has no affiliation with either site - I have been using and recommending them for years - trouble free.
PartSelect has a great schematic database for locating the part on your unit and great "testimonials" for each part that often times includes HOW-TO information.
RepairClinic has pictures of each part they sell and also a great how-to and troubleshooting for basic repairs.
If your unit has never been serviced - there should still be an original service manual enclosed in plastic taped to the inside of the shell.
In the service manual are Error codes, maintenance procedures, and troubleshooting steps you can follow.
Anything too complicated or beyond your scope should be handled by a professional.
If you think you want to tackle the repair - and have gotten stuck on a step - reply to your question and I will be glad to help you out.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
SOURCE: During the spin it makes a loud high pitch noise.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question^%$#
SOURCE: I have a kenmore Elite Oasis Top Loading Washing
Hi
This issue can either be due to the suspension rings or due to motor issue. Please check this link for exploded diagram of your washer---
Kenmore Elite Top Load Washer 110.28032701 Diagram
Also, check the stator motor and the retainer, make sure no parts are missing. Hope this helps... Please post back if you need more information.
Daniel
