Question about Whirlpool WTW6400SW Cabrio Washer
Whirlpool washer cabrio stuck on spin cycle
Lid locked stuck on blinking 8 mins.
    New Friend:
    Problem Solver:
  • 5 Answers
Solution- ID- is in the control program and the door lock. If, there is any warrenty on it, call Whirlpool and a Tech can help you with it.
Posted on Sep 10, 2012
6ya staff
SOURCE:
Anonymous
SOURCE: Washer Stuck in Cycle
I checked the lid switch and nothing appears to be broken (cracked plastic). What exactly should I be looking for? Also during the agitator cycle I opened the lid and the washer stopped working. Does that mean that the lid switch is working?
Posted on Jan 14, 2008
Prakash R
  • 1382 Answers
SOURCE: Will start the wash cycle and DL come on and light
"dl"indicates a door lock error. A Door Lock Error occurs if the door cannot be unlocked. It will try to lock it 6 times before displaying the error.
Check for the following when dl occurs:
  • Door Lock Mechanism broken.
  • Check Door Lock/Switch Assembly for foreign objects
  • Check Wire Harness connections to the Door Lock/Switch Assembly and Central Control Unit (CCU)
  • Door Lock/Switch Assembly Failure
Thank you !!
Posted on Jul 28, 2010
jyackle5
Jyackle5
  • 8197 Answers
SOURCE: code sd on cabrio washer
The sd code means to much suds. You need to get a bettter he detergent.
Good Luck and Please rate FixYa!
Posted on Dec 20, 2008
fixer444
  • 106 Answers
SOURCE: Whirlpool Duet stuck on spin cycle
Press 'end of cycle' for over 3 seconds. Perhaps you have to check your filter, maybe clogged.
Posted on Mar 01, 2009
yan candie
  • 39 Answers
SOURCE: Whirlpool washer grinding noise when draining
there could be something in your pump.....remove the pump and see if there is not something inside...
Posted on Jul 04, 2009
Blinking lid locked light and green sensor light on machine won't start cycle
The good ol' Whirlpool Lid Lock Flashing Light Problem - ApplianceBlog
www.applianceblog.com/.../42456-The-good-ol-Whirlpool-Lid-Lock-Fl...
Dec 11, 2013 - 10 posts - ‎3 authors
Red Lid Lock light flashing intermittently when you try to start a cycle. ... I'm going to post what SENSING does first, then you will need to locate your tech. ... start with thelid lock on and blinking, or the unit will not start and spin. FIXED Sense light on light humming noise won't start ...
Aug 9, 2015
Whirlpool WTW4950XW not working
Nov 2, 2013
Stacked GE washer/dryer lights Blinking doeent start at ...
Feb 20, 2012
More results from www.applianceblog.com
Washer Sensing led (Green) on with the lid locking led (Red ...
www.shopyourway.com > Manage My Life > Questions
... this: Sensing led (Green) on, the lid locking led (Red) blinking with a clicking noise ... red led light goes off green led light stays on and the washer does not start.
Oct 27, 2015 | Washing Machines
Lid locked light on, will not release
The lid lock light won't stop blinking. - Fixya
www.fixya.com/.../t14714916-lid_lock_light_won_39_t_stop_blinking
Oct 21, 2012 - The lid locked keeps blinking and I can not start a cycle. - WhirlpoolLSB6200KQ Top Load Washer question. ... Whirpool cabrio wtw5500xw top loadwasher will not start lid light flashes then goes out and into flashing pause ...
Whirlpool washing machine_ lock light flashing_ nothing ...
? 1:53
www.youtube.com/watch?v=zrV9w6Z5LAU
Mar 3, 2012 - Uploaded by briantaylor62 Whirlpool washer wont start a cycle, lid does lock and the locklight ... a cabrio as well that just has the lid lock flashing and nothing happens , I ...
Flashing Lid Lock Light: How to Troubleshoot Errors on Your ...
? 1:23
www.youtube.com/watch?v=nttHsAX2_OM
Mar 27, 2015 - Uploaded by searspartsdirect
The lid lock light on VMW washers, made by Whirlpool, Kenmore and Maytag, will flash whenever there is a ...
Oct 12, 2015 | Washing Machines
Why is my cabrio whirlpool top load washer getting stuck with the lid lock on after each cycle,i have tried unpluggin it and turningt on again, i have to manually go through all the settings on my was
Sounds like lid is locking so that part is most likely good. The lid lock plugs directly into main control in console. Sensors are found in mode shift actuator or hall sensor depending on model. I would try replacing sensor first since it is least expensive. And then control if sensor is not problem.
Aug 26, 2017 | Washing Machines
Why is my washer stuck in the spin cycle
hi
this might be too obvious but did you try to unplug the washer for at least 5 min to completely reset the computer in the washer ?
Jun 08, 2014 | Whirlpool Cabrio WTW6600SBT Top Load...
Cabrio washer stops spinning and doesn't restart
it sounds like the water pump is not emptying properly, blow down the water outlet pipe to see if is clear if not go to the water pump and clean it out there is probably a button , paper clip or other debris preventing it from doing its job eric
Dec 25, 2017 | Whirlpool Cabrio WTW6600SBT Top Load...
LD ERROR CODE AND WONT DRAIN LID WILL LOCK
try any button sequences yet . try holding start button and a cycle button hold both down to reset
Apr 01, 2013 | Whirlpool Cabrio WTW6800W Washer
Washes but locks on spin cycle does not spin or dran
Does the lid lock when it gets to the drain cycle? If not then you need a new locking mechanism. The tab in the mechanism breaks off and it tries to lock the lid but cant. If it hums when it gets to the drain cycle, you have something caught in the pump or a bad pump
Aug 24, 2012 | Whirlpool Cabrio WTW6600SBT Top Load...
Whirlpool cabrio wtw5500xw1 will not spin
This is caused by a major design flaw in this washer. I have the same washer and am having the same problem. If you take the back cover off by removing the small metal cover over the tube coming from the controls and all the screws around the large lower metal cover, you can gain access to the back of the washer. Take the foam noise reduction pad out of the bottom of the washer. There is a white opaque plastic shroud on the bottom of all the motors covering the belt. Remove it by taking out the screw in the front bottom and back bottom of the shroud. You will most likely see that the belt fell off. This is because the drive pulley for this washer has no ridge on it to keep the belt on and most likely rubbed on the shroud and cut a perfect groove in the shroud, allowing the belt to fall off. SHORT STORY: This washer is a piece and you are probably out of warranty. There is no actual way to fix this problem unless Whirlpool has made a new drive pulley that has a ridge on it to keep the belt on the two pulleys. Good luck. I bought mine for $700 and it worked for two years before this happened.
Mar 04, 2012 | Whirlpool Cabrio Washing Machines
My lid lock button is stuck and will not unlock....when i 1st went to the washer it was on spin and lid lock and i pressed the start button which is suppose to unlock this lide but that has not...
That happened to me once. I just unplugged the machine for a few mins and it released the lock when I plugged it back in. I've got my fingers crossed that it doesn't happen again.
Aug 27, 2011 | Whirlpool Cabrio WTW6600SBT Top Load...
Whirlpool cabrio .....
I imagine it it has detected suds and is doing mini loads to correct the problem. I have a manual HERE
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Feb 12, 2010 | Whirlpool Cabrio WTW6600SBT Top Load...
Whirlpool WTW6400SW Cabrio Washer Logo
435 people viewed this question
Marvin
Marvin
Gerry Harvey
Gerry Harvey
jimorris77
