I have an Emerson Jumbo Universal Remote and a Protron DVR device but I have been unable to control the DVR by either method of identifying the compatible code. If I use the automatic scan pressing the on/off button continually, after about 90+ iterations it will turn off and then I press the Enter key. The unit will not come back on unless I use the remote that came with the unit. If I turn it back on using that remote the Emerson remote will still turn it off but not back on again.
Please help!
SOURCE: lost guide book for emerson jumbo universal remote. need code
My guess is that it's the same as the Shaper Image Jumbo remote. Go to http://mscustomercare.com/. There's pictures of both. I just downloaded free instructions, will try them myself tomorrow.
SOURCE: INSTRUCTIONS NEEDED FOR THE SHARPER IMAGE - JUMBO UNIVERSAL REMOTE
Hello kls1996... programming your remote is rather easy. The easiest way (thanks to The Sharper Image Jumbo Remote being a LEARNING SMART remote) is to do the following:
1 - Point the head of your Sharper Image remote at the head of your Sanyo TV remote (nose to nose so the clear bulbs on each remote are facing each other).
2 - Press the "TV" button on your Sharper Image remote (located in the upper left-hand corner).
3 - Hold the "LEARN" button on your Sharper Image remote (located in the left edge under the volume buttons) until the red light flashes.
4 - Press the key on your Sharper Image remote (e.g. Volume Up or +VOL)... the red light will go solid (indicating that it is waiting for a signal from the other (in your case Sanyo) remote.
5 - Press the key on your other remote (in your case the Sanyo remote) that you want programmed in your new Sharper Image remote... the red light will flash rapidly again.
6 - Repeat step #4 until you have programmed each key.
7 - When done... press the "LEARN" key on your Sharper Image remote. Your Sharper Image remote should be programmed to operate your device (in this case, your Sanyo TV).
NOTE: You can program other devices such as your VCR, DVD, VHS, SAT, CABLE, etc. and not just one device.
SOURCE: i have a jumbo emerson remote for a tv/dvd combo i
I found that this website should have all the codes and instructions for most remotes
http://www.xdiv.com/remotes/
or http://www.remote-codes.com/
if this helps please give a fixya rating
SOURCE: codes for jumbo universal remote
Codes for jumbo universal remote
Sorry to here about your emerson remote problems.
The best thing to do is go to emerson.com and search for your device by number.
You will be able to find and print all the codes you need for whatever devices.
Hope this information has been of some help.
Please rate your technician, as they take the time to answer your questions. !!
Even if you disagree, it shows us that you have taken the time to answer.
Thanks,
John Ray
[email protected]
