Question about Whirlpool Ultimate Care II LSQ9549L Top Load Washer
Whirl pool washer bangs when in spin cycle
When my whirl pool washer ultimate care 2 is in spin cycle it bangs against the sides .
  • 640 Answers
If new did you remove shipping strap in back..the unit cant lean more than 2 degrees..make sure clothes are even in tub..try to wash clothes alike..
Posted on Dec 25, 2008
6ya staff
SOURCE:
Drum is loose during Spin and Rinse cycle and banging against side of washer
If it is under warranty, call Whirlpool at 1-866-698-2538. If it is out of warranty, try running the washer with no clothes in it in spin cycle. If it runs fine empty, it may be that when you had clothes in it they were not balanced evenly in the tub. If it runs off balance when empty, then a spring may have broken or come off. Contact an appliance repairman.
Oct 31, 2013 | Whirlpool WTW4880AW 3.4 cu. ft. Top Load...
I got a whirl pool cabrio and it makes a noise noise and will not drain
Problems with a washing machine not spinning or not draining are often inter related..
If you are having a problem with your top load washer then check out this tip...
Washing Machine does not Pump or Spin
If you are having problems with your front load washing machine then checkout this tip...
Front Load Washing machine not draining and or not spinning
heatman101
May 08, 2011 | Whirlpool Ultimate Care II LSQ9564J Top...
On the spin cycle, it makes a banging noice, rythmic, about 2 per second....only on the spin cycle... can you help???
The spin cycle is used to rid the water by centrifugal force. As the tub spins, the water iis forced out of the clothes. The banging noise comes from the weight of clothes being on one side making the load unbalanced. The machine will absorb some minor unbalancing. If it gets real loud & the machine starts dancing, shut the machine off by raising the lid, when tub stops, rearrange clothes.
Louie Almond
Mar 27, 2011 | Whirlpool Ultimate Care II LSQ9549L Top...
Excesive vibration on spin cycle machine is level and solid whirl pool top load
Most manufacturers now recommend that you install an anti-vibration pad under the stock feet of the washing machine. For top-loading washers, Anti-Walk Silent Feet can't be beat. A set should cost aroudn $40 but is worth every penny of that. They take just a few minutes to install and will last longer than the washer will. The best price I found on these washer anti-vibration pads is on Amazon.com.
Feb 22, 2010 | Whirlpool Ultimate Care II LSQ9564J Top...
Washer agitates off balance and makes a loud banging sound until movement stops at the beginning of rinse cycle, advice?
If it makes this noise in the agitate mode and not during the spin cycle, I would suspect that the transmission is going.
Jan 03, 2010 | Whirlpool Ultimate Care II GSW9650LW Top...
GE Profile - Loud knocking on spin cycle
Just random input, I apologize if this is of no help to you. I've only experienced this with my washer when clothes somehow get bunched up on one side of it.  The best I can tell you at the moment is to make sure there is relatively equal distribution of clothes around the "washer bucket thingy" if you hear the bang bang bang again.
Jul 06, 2009 | Whirlpool Ultimate Care II LSQ9564J Top...
Whirlpool ultimate care 2 washer wont spin
Are you in the Delicate Cycle? Do you have spin speed control set for slow?If both answers are no,than what is the model & serial number??
Apr 28, 2008 | Whirlpool Ultimate Care II LSQ9564J Top...
Whirlpool Ultimate Care II LSQ9549L Top Load Washer Logo
397 people viewed this question
Marvin
Marvin
Gerry Harvey
Gerry Harvey
jimorris77
