https://www.thespruce.com/how-to-clean-a-washer-lint-trap-2147322
Washing machines vary by manufacturers and models and some don't have a lint trap. Lint pumps out of the washer with the water, during the drain and spin cycle, and goes down the drain.
https://homeguides.sfgate.com/frontload-washers-lint-trap-89363.html
Sep 23, 2010 - I clean out the dryer lint trap every time and that doesn't seem to matter. ... If your washing machine is older, there is a chance that it has a built-in lint trap. If this is the case and ... Follow the directions for cleaning the lint filter.
www.whitegoodshelp.co.uk > ... > DIY Washing Machine Repair Help
Jul 8, 2013 - Common problems and faults with a washing machine pump filter. ... a pump filter to protect the pump from a build up of lint, and obstructions such as coins. ... towel to catch water and don't take it out at all if the washing machine still ... If you can't see any blockage, or there is just the odd button in there that ...
3 hours ago - Locating fluff filter on aeg washer/dryer . After using the dryer facility the following wash resulted in garment containing patched of fluff ...
There is no lint trap on this washer. There is a filter in the hose that goes from the tub to the pump that occasionally will get plugged with lint, but it is not designed to be regularly cleaned. During normal usage, the lint is designed to be pumped out with the water.
There is no trap per say. The lint catcher is self cleaning when the water is pumped out. It sounds like you are overloading it and the clothes are hitting the agitator. Operation should be agitation by water movement not beat by the plastic fins, run a wash cycle hot water no clothes to flush things out and try smaller loads. Eric
To find the filter you need to do the following steps. Find your lint trap. Lint traps in washing machines can be in the agitator (the large plastic piece in the center of the tub), at the top of the washer on the rim of the tub, or attached to the washing machine's drainage hose. Pull out the agitator tube to check for the lint trap. Peel any loose lint from the filter. Scrub away lint that doesn't peel off easily with a heavy-duty paper towel or a wet sponge. Feel your way around the top rim of the washing machine's basin. If you locate a trap, pull it straight out of the machine. Peel away loose lint and follow up with a wet sponge or heavy-duty paper towel. Check your machine's drainage hose for an attached lint trap. Remove the trap and peel the top layer of lint off. Rinse the trap in low-pressure, warm water. Reattach to the drainage hose. Check for and remove any lint or debris that may have dropped into the washing machine basin during the cleaning.
Let us know if you want any further clarification.
Thanks for contacting fixya.com
