Need part number for the knob? How do you open the front panel?
I believe the selector knob on a Whirpool just has to be turned counter-clockwise with the selector pushed in. It will spin off the shaft and then the outer indicator dial will pull off. The shaft also has a keyed slot that will only allow the dial to be removed and installed one way, so there should be no question as to how it goes back on.
Was there a reason as to why you are removing the washer selector knob? If this is a simple matter of replacing a broken water temperature selector, you shouldn't have to remove any of the control knobs to gain access to the selector. The entire front panel comes off by removing the screws holding it in place. That way you can access the broken selector from behind the front panel much easier. Just remove the panel right above the washer top (under the dryer) and it should expose the front panel mounting screws. Remove these screws and the front panel comes off. Just make sure the unit is unplugged before you begin. I hope this helps you. Let me know if you need further assistance.
SOURCE: whirlpool front loader duet sport washer door will not open
without complete f code hard to pin cause but suspect pump not pumping out remove bottom cover reach up to lock area pull small tab down to unlock door remove as much water as possible remove pump clean out by turning counterclockwise clean pump and connecting hoses reassemble and ck
SOURCE: Whirlpool Duet Washer Model WFW9200SQ leaks
Removing the lower front panel would help immensly in determing where the leak is coming from. Most commonly, the leak is caused by the door bellow (gray rubber boot) leaking. If you pull back the rubber folds in the door seal and inspect around the perimeter, you may find that it has become ripped or torn. This is normal as they do wear out with age. If you determine the door bellow to be leaking you will need to replace it. The following link explains:
http://www.fixya.com/support/r385211-replacing_door_bellow_whirlpool_duet
The instructions to remove the lower panel are included in the link I provided. Another common symptom of a leaking bellow is the front counter weight on the drum will be wet.
If the bellow is intact, with no obvious signs of holes, check the water inlet tube that is located on the left hand side of the bellow to ensure it is fully inserted through the bellow properly. The inlet tube, if not inserted through the rubber correctly, will cause the water to run behind it and out the bottom of the cabinet. Push the tube through the rubber until it reaches the flange on the inlet tube.
Also check the following:
1. Check the drain line that runs from the bottom of the wash tub to the inlet side of the drain pump.
2. Make sure the drain pump reservoir cap is secure and not leaking.
3. Check the along the seam of the wash tub as well. There is a tub gasket that holds the two halves of the tub together that can develop leaks.
If you have any questions, please let me know. I hope you find this information helpful.
SOURCE: Door locked on compact Whirlpool front-load washer
This worked for me. I turned off the washer and hit the area on the washer directly to the right of the door handle (not hard enough to break something or cause a dent). It popped right open.
SOURCE: Problems with Whirlpool WFC7500VW Washer?
A10 is a long drain cycle. Check the drain hose to make sure it is not clogged or kinked. Could be a clogged or bad pump.
