On device manager missing optical drive
In device manager, delete something like a USB device and perform a hardware scan with the menu item and it will detect the optical drive if its running ok. Then you can upgrade the driver for motherboard or the cdrom if exists on their web site. If the issue persists, check BIOS and see whether it is disabled in any way before you try to disassemble it and tighten the cable connections or try that cdrom on other machines.
SOURCE: Error 39, corrupt DVD/CD-Rom Drive
Dear NICK,
its a windows registry related problem, you can fix it through :
This method, or task contains steps that tell you how to
modify the registry. However, serious problems might occur if you
modify the registry incorrectly. Therefore, make sure that you follow
these steps carefully. For added protection, back up the registry
before you modify it. Then, you can restore the registry if a problem
occurs. For more information about how to back up and restore the
registry, click the following article number to view the article in the
Microsoft Knowledge Base:
322756 (http://support.microsoft.com/kb/322756/) How to back up and restore the registry in WindowsLog on to Windows by using an account that has administrator rights and permissions. Then, follow these steps.
Step 1: Start Registry Editor
loadTOCNode(3, 'resolution');Click Start, click Run, type regedit, and then click OK. Registry Editor starts.
Step 2: Delete the UpperFilters registry entry
1.
In Registry Editor, expand My Computer, and then expand HKEY_LOCAL_MACHINE.
2.
Expand SYSTEM, and then expand CurrentControlSet.
3.
Expand Control, and then expand Class.
4.
Under Class, click {4D36E965-E325-11CE-BFC1-08002BE10318}.
5.
In the right pane (topic area), click UpperFilters.
Note An UpperFilters.bak registry entry may also appear. To delete the UpperFilters registry entry, you must click UpperFilters and not UpperFilters.bak.
6.
On the Edit menu, click Delete.
7.
When you receive the following message, click Yes to confirm the deletion of the UpperFilters registry entry:Are you sure you want to delete this value?The UpperFilters registry entry is removed from the {4D36E965-E325-11CE-BFC1-08002BE10318} registry subkey.
Note Do not exit Registry Editor. You must have this program for the next step.
Step 3: Delete the LowerFilters registry entry
1.
2.
3.
4.
5.
In the right pane (topic area), click LowerFilters.
Note An LowerFilters.bak registry entry may also appear. To delete the LowerFilters registry entry, you must click LowerFilters and not LowerFilters.bak.
6.
7.
When you receive the following message, click Yes to confirm the deletion of the LowerFilters registry entry:Are you sure you want to delete this value?The LowerFilters registry entry is removed from the {4D36E965-E325-11CE-BFC1-08002BE10318} registry subkey.
8.
Exit Registry Editor.
Step 4: Restart the computer
loadTOCNode(3, 'resolution');If a CD recording program no longer works after you restart the computer, you must reinstall the CD recording program.
SOURCE: cd/dvd rom not working on hp laptop
Is the Drive detected in the BIOS? Can you boot from your Windows or any bootable disc? If so try this solution:
Always backup your registry before editing and use care to find exact key!
Start Registry Editor (Start, Run and type in regedit then click)
Find
"UpperFilters" and "LowerFilters" (and "UpperFilters.bak"
"LowerFilters.bak", if they exist) value under the following key in the
registry, and delete it:
HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\Class\{4D36E965-E325-11CE-BFC1-08002BE10318}
Quit Registry Editor.
Reboot.
NOTE: You might need to reinstall any CD recording apps you have, if they start to not work completely, after doing this.
SOURCE: i can't boot from external usb dvd/cd drive
please try to remove the connection between motherboard and vd/dvd drive.
then perform the previous steps.
SOURCE: My cd/dvd drive is not working. there is power and
Try downloading the cdgone file from the link below and run it, it should solve your problem
http://www.geekstogo.com/forum/CDgone-file8.html
SOURCE: TSST Corp CDDVDW TS-L632N ATA DEVICE
Try to uninstall your optical drive on device manager and restart your system.
->if that doesn't work try a firmware update.
->if that still doesn't work,replace optical drive.
that should resolve your problem
