If you have forgotten the pattern it will ask you for your gmail login. If not then you need to do a hard reset which will bring your phone to factory reset and you will loose all your data on phone (contacts, messages, apps etc).
You may try default phone and security code to remove restrictions. ur defalt phones codes is 12345 or 00000 u can use it
Type *#06# at the mobile screen to know IMEI no of your mobile. send the IMEI no to me and i will reply you with unlocking code. IF Problem not Solved So Please New Software install in the Phone Problem will Solved
Hi, you can get the factory unlocking code with the following service for your phone model: http://www.fastgsm.com/en/lg/lg/optimus-l3-e400/unlock-code-usim-locked
All data will be lost! Remember to back up any important data before doing a hard reset.
When the phone is turned off, press and hold the Home key + Volume down
key + Power key for over 10 seconds. When the screen shows the LG logo,
release the Power key.
After the screen shows the hard reset screen, release the other keys.
Leave your phone for at least a minute while it performs the hard reset, then your phone will be turned on.
anothewr way is :
reset phone to factory settings and
erase all the data on your phone, touch Menu > Settings> Privacy
> Factory data reset > Reset phone.
Resetting the phone does not erase any system software updates you have downloaded or any files on your microSD card,
such as music or photos. If you reset the phone in this way, you are
prompted to re-enter the same information that you did when you first
started Android.
Unlocck codes are not available or is legal However there are sites that offer this to be done but with your own risk.Best is to get this checked at the samsung center or with the provider. You can check this out on some of these;
