Question about Goodmans GTVL19W17HDF 19 in. LCD TV
Goodmans 19 in TV tried automatic and manual tuning but still no input,keep getting channel 8oo's
    New Friend:
    Problem Solver:
  • 9 Answers
Try calling cable operator
Posted on Sep 12, 2012
5 Suggested Answers
6ya staff
SOURCE:
SOURCE: Hi, I accidentally tuned my goodmans
There should be a button marked source,press this then scrol to the one marked dtv,hope this helps.
Posted on May 12, 2011
danielsowney
SOURCE: Goodmans GTV69RFDT Television had all freeview now only getting 3 channels
I have just brought a one for all remote and the code on the back of my goodman tv isnt matching any of the codes on the remote booklet, i have tried selection search and that doesnt work either. Any suggestions on solving this head doing problem.
Many thanks
Dan Sowney
Posted on Apr 15, 2011
kb8dns
Rod Wallberg
  • 494 Answers
SOURCE: Goodmans TV needs re tuning
Very likely that where you are the over the air signals are now broadcast in digital format and you need to by a converter box to use an older television. Check places like Walmart or Best Buy or Radio Shack
Posted on Apr 13, 2010
olayoju victor
  • 191 Answers
SOURCE: Says no tv input
make sure your antenna is effective or you can use dvd or video to test it.you can use your system to test it as a monitor.if all this fail to work, change your analog to digital conversion board
Posted on Oct 11, 2008
I have an indoor digital aerial connected to a free view box but when I automatically tune the TV it comes up with no channels found check aerial connection
Possibly. Try rotating the antenna a little bit and retry tuning. Keep on doing this until you get your channels. If this doesn't work, raise the antenna as high as possible and try again.
Dec 20, 2014 | Goodmans GTVL19W17HDF 19 in. LCD TV
Why does my digitrex tv freeze at 19% when doing a digital channel search?
It would have been helpful if you had provided the model number of the combination unit. It is likely the channel signals are weak or there is some interference.
Try to use the manual tune option for a few main channels to see whether you are getting good signal. If the signal is ok then power off the tv at the mains and start again. I am assuming the TV antenna is external roof mounted.
Aug 07, 2014 | Televison & Video
Goodmans 19 television manual
please send me an email to LBrown18062@hotmail.com and I will sen you the user manual. please put "goodmans manual" as the subject.
Sep 12, 2012 | Goodmans Televison & Video
Bought a 2nd hand N64 & don't know how to set it up on the tv as no instructions.
You now need to find a channel on your TV that ins't used for anything else (eg an old vhs player or non-digital tv) then whilst on that channel you need to go into your TV's menu, there is often a button both on the remote and TV itself for this. This is where you turn on your N64 if you haven't already. You then will need to go onto automatic tuning (or if you prefer, manual tuning, in the programme section (if you dont have a programme section, just srcoll through each section till you find automatic tuning) your TV should then start to search for channels, after a little while of searching it should find the N64's frequency it may be a terrible picture that is mostly fuzz you can either carry on the tuning to see if it'll find it better or just head straight to fine tuning (if you decied to keep going you can still fine tune for the best picture quality possible and also if the TV doesn't find it just follow the previous steps till it locates the N64 again) once fine tuned you will need to store this new channel and then you can go ahead and enjoy countless hours of fun on the worlds best gaming console. (If the automatic tuning doesn't find the N64 at all try manual tuning). If you have any other issue with the console itself just drop me an e-mail at garleet@hotmail.co.uk. Hope I was a help.
Jan 20, 2012 | Video Game Consoles & Games
How to tune the channels
You can tune the channel by Auto programming button in the setting area and then press Auto Scans all available channel option to tune the channel automatically, try it and still facing the problem read the manual carefully for better understanding or you can also call the online customer care available in the manual.
Kindly rate my help++ Thank you
May 09, 2010 | Philips Magnavox MT1905B 19" TV
Try to do automatic tuning and manual tuning but keeps coming up no tv input???????? the make of tv is umc hdmi ready 19 inch
make sure that you have an antenna hooked up, and if the antenna is powered, that it is plugged in and turned on. You may also need to point the antenna towards the transmission towers or have near a window.
Feb 07, 2010 | Televison & Video
First ensure that the TV input is set on the Freeview channels, just in case.
Then check the antenna, when Freeview does not get all channels, it is always the aerial (antenna).
Many areas in UK have still poor reception. If you use an internal antenna, go to Argos or Currys and buy an amplified antenna for freeview, that will improve the signal.
Oct 15, 2008 | Goodmans W280NS Television
Goodmans w282ns silver
in your remote control there will be one button calles ASM or auto search mode you press it (or auto) tv will tune one by one channel automatically & it will stop. now from prog. button you can up &down channals. from vol +&- vol up& down. good luck.
Sep 19, 2007 | Goodmans 289NS 14" TV
Connecting security camera
you can put at av1 or av2 or any video input jack. automatically camera works , and select the tv input contols very easyly..
Aug 30, 2007 | Orion1934 19" TV
Goodmans GTVL19W17HDF 19 in. LCD TV Logo
498 people viewed this question
Top Goodmans Televison & Video Experts
Ekse
Colin Stickland
Colin Stickland
martin hogg
Are you a Goodmans Televison and Video Expert? Answer questions, earn points and help others
