If you see brown marks on the center top of your page then its your feed roller... hp feed rollers come out easy... Get some rubbing alcohol or hand sanitizer solution and clean with a paper towel... Make sure to dry your feed rollers then put them back in... that should clear up your issue... if that still does not work you may need to replace feed rollers
HP LASERJET 1320 FEED ROLLERS TRAY 2
If it feeds ok but gets stuck at the back then chances are your fuser is bad. The belt is most likely ripped.
HP LASERJET 1320 FUSER ASSEMBLY
I’m happy to assist further over the phone at https://www.6ya.com/expert/norman_d2fa496dce30c65d
