After warming up printer.... if we give the command to print it picks paper and give error 52.00 printing error
HP LASER PRINTER 2300 ERROR 52.X
1. A temporary scanner start up error.
2. This can also be the shutter tab on the print cartridge. Replace the toner cartridge.
3. Replace the scanner ***'y.
4. Replace the engine board.
Tallon41
MAYBE try this if you have a non-HP cartridge (for all who have the same Problem :) ) The original HP cardridge moves a shutter cap tab away from the laser unit by moving a little pin above the cardridge slot (in the right corner). You could fix the pin stuck in or maybe take it apart and remove the shutter tab from the laser unit ->REMIND that it is a security feature to prevent the laser beam coming out if no cardridge is installed. so be careful and have a nice day :)
SOURCE: hp printer does not print out when command is issued
not specific enough, is the error on the pc or the printer?
in any case here is the manual check here for connections and trouble shooting.
http://www.retrevo.com/s/hp+6210+manual
SOURCE: Hp laser jet 1020 paper jam and not printing
REmove cartridge, and open rear door, might be all scrunched in very back fuser unit, if you can't remove it without damaging the rollers then it will need to be pulled to bits
SOURCE: No Paper Pickup error
Check all this ---------
1.check the paper pickup roller may be its not functioning
proper.
2.check the paper pickup sensor(clean this)
3.check the paper pickup tray for proper work.
4.check the gear of paper pickup.
thanks
SOURCE: paper out jam in hp laserjet 1020
Please visit this below mentioned link to troubleshoot your printer problem.
HP LaserJet 1020 Series Printers - Clearing Paper Jams
Thank You
SOURCE: not printing in foxpro 2.6 dos to hp laser jet 1020
You write "type the above line at command prompt". I dont't know Where exactly to write? Can you tell me!
HP 1008 Laser jet printer
HP 1505 Laser jet printer
HP 2035 high resolution printer
good luck
