The printer works but the scanner does not. Using it with a Mac. It used to work.
Canon PIXMA scanner problem
If the device scanner works with a windows-based PC, then your problem is NOT with the printer.....it is with the MAC. You can also test it by trying to "copy" something. If it can do that, (i.e. use the scanner to create a copy,) then mechanically, it has no problems with the scanner itself.
Tallon41
Thanks much. I have no idea whether it works on a PC. The copy function does work. How can I fix this problem? Is there a driver or patch I can upload?
sorry, I'm not a mac guy, but if the copy function works, the problem is with the mac.....you could try re-installing the software it came-with. Tallon41
SOURCE: cannot operate scanner
pls check if a software like smarthru4 is bundled or not??
omnipresent
Just posted two solutions to my problems. see here.
http://www.fixya.com/support/t134648-scanner_not_working
Hope it helps
SOURCE: Epson multifunction printer/scanner DX6050 drivers for Mac Leopard
yeah thanks for the help not
SOURCE: Mac OSX 10.4.11 Error when installing the Epson NX400
If you're running the install program from the install disk CD, it may be attempting to create a work folder on the CD instead of your hard drive. I would drag a copy of the install program onto your hard drive first and then launch the copy on your hard drive.
Let me know if that solves your install woes...
best of luck on this.
K
SOURCE: the printer works, but the scanner does not.
Vista does not have drivers for older peripherals :( that was a major problem when it first came out. I don't know if your scanner manufacture has an updated driver for vista or not but I would check with them and see if they have one you can download and install.
This would be helpful if it helped me do whatever I need to do to my Mac to use the scanner.
