Maytag MZD2766GES Side by Side Refrigerator Logo
Posted on Sep 12, 2012
Drip pan remove drip pan from model mzd2766ges maytag fridge
  • ELLYE OVEDIA
    ELLYE OVEDIA Feb 25, 2014
    there is no drip pan at the bottom of the ref rig.
2answers
I have a maytag side by side refrigerater psd265LGES fruit flies coming out of ice machine/water dispenser.I scrubbed the whole fridge,yet still have them.Is there a drip pan on this fridge.
I would lift up the drip tray and clean that out making sure nothing is under it. If it is coming from the dispenser then there is no reason to check under the fridge unless you think something is under there like grapes or berries.
How do i fix my fridge that stopped working?
To aid in troubleshooting, the link below may be of help:
MAYTAG MAYTAG REFRIGERATION Parts Model MZD2766GES Sears PartsDirect
You may have a failed defrost heater.
Mdz2766ge maytag fridge; water puddles on floor when defrost kicks in
Check the drain tube from the defrost coil near the evaporator to the drain pan.
Drip pan replasment on mzsd2665heq
Hello there,
To remove and replace the drip pan on your refrigerator, please follow the instruction below:
  1. Unplug the electrical cord of the Maytag refrigerator from the power outlet before attempting to remove the drip pan.
  2. Detach the grille on the bottom of the refrigerator in the front, pulling the grille off by hand.
  3. Place a towel in front of the refrigerator to clean up any spills that may occur while pulling the drip pan out from under the appliance.
  4. Slide the drip pan forward until is free of the Maytag refrigerator.
  5. Empty the drip pan in the sink.
  6. Replace it with a new one,
  7. Then you reverse the process to reassemble it back together,
  8. Plug it back to the power outlet.
Hope this helped. All the best Elect_Comp
Need to remove drip pan
Hi, This pan can not be removed without taking the whole frame apart. Best thing is to try and get a long brush (hardware stores sell them) and try and clean it that way.
Using very hot water might help loosen the grime in the pan.
I hope this helps you.
Please let me know if I can assist you further.
Vic
7helpful
3answers
Freezer Drain Clogged
I use a turkey baster and force hot water right down the drain hole. If still blocked I push a coat hanger wire down the drain, usually works but you need patience with the hot water.
Top Maytag Refrigerators Experts
vince
Johnny 1000
Jesse Walters
Jesse Walters
Are you a Maytag Refrigerator Expert? Answer questions, earn points and help others
