Question about LG Flatron L1951S-SN 19" LCD Flat Panel Monitor
No sound on LG Flatron W2241T monitor
Can not find where to connect external speakers or get sound?
The LG Flatron W2241T does not have speakers.
Posted on Feb 06, 2009
    Genius:
  • 2,120 Answers
Plug into the LIME colored port on your computer.
Posted on Dec 26, 2008
6ya staff
SOURCE:
I connected a flatron w1952tq to my computer and I have video but no audio. How do I fix it
do you have speakers on your monitor? If yes, check the wire connecing hte sound to the speakers
Jun 11, 2014 | LG Flatron L1951S-SN 19" LCD Flat Panel...
Connecting tv external speakers
If you connected R/W RCA cables to the AUDIO OUT RCA jacks on the rear of the TV and connected the other ends to the TV AUDIO IN jacks on the receiver, you should be able to select an input on the receiver that will deliver sound to the Bose speakers. If you went to TV setup and selected external speakers, you directed output from the TV amplifier to external speakers which is not what you want.
Jan 27, 2014 | Televison & Video
No sound from speaker but through ear piece I get sound.
Many devices will automatically switch off the large speaker when ear phones are plugged into them. Also there may be a switch or button or prompt on your radio to switch between regular speaker and ear phone jack. Look for that first.
Try connecting and disconnection ear phones while listening to a station and see if the problem is intermittent. If is works sometimes but not every time then it is most likely an internal connection.
You will have to access the inside of the radio to investigate further. Connect a working external music or sound source with speaker wire to the terminals inside the radio that connect to the radio's speaker. If the radio's speaker works with the external sound source then you know it is a bad connection inside your radio. If the radio's speaker does not work with the external sound source then it is most likely a faulty radio speaker. Look closely for a broken solder point or broken/disconnected wire.
Sep 10, 2013 | Eton E100 SW/FM/AM Radio
No sounds comes out in headset but external volume is ok
Try to use external speaker. connect it where you usually connect your head and check if it work . If ever the external speaker will work it only means that the problem is your headset ( defective )If in case the external speaker will not work it means the problem is the terminal ( the port where the headset or external speaker connection )
Apr 01, 2012 | Computers & Internet
Can't turn off internal speakers when i have external speakers connected via headphone socket
First, check if you put the connector for external speakers all the way to the end. Sometimes when the connector isn't fully inside both internal and external speakers will work. After you do that, once you connect the external speakers, go to the sound settings in windows and look for the volume mixer. You can regulate the sound for each type of speaker there.
May 04, 2011 | Computers & Internet
I dont have a hdmi connection to my lg e2350vr flatron monitor and there is no sound is it because i dont have the hdmi lead
the dvi (or vga) connection from a graphics card to the monitor does not carry audio.
in this case, the cable doesn't matter because your monitor doesn't have speakers. it does have an 3.5mm headphone jack, but that is only to transfer sound if it had come in with hdmi cables.
if you want sound, you will need external speakers
Jan 13, 2011 | LG E2350VR 23" Monitor
Hello, I have a very old mitsubishi color tv, model cs 2657r, which I purchased in the late 1980s. The picture is still great, and I'm trying to connect two small external speakers, though the internal...
Try stripping the speaker wires and exposing it about 1 inch. Then connect the speaker wires in a way that the part that grips or holds the wires touches the metal part and not the insulation. If there's still no sound, Please check the external speakers to see if it's working by using them in another device like a home system or audio player or maybe another tv that has an external speaker port. If not, mostly likely the switches are defective and needs replacement by a qualified technician.
Hope this helps.
Oct 25, 2010 | Mitsubishi CS-13103 TV
No sound
check cables ,,check the menu to c if someone hit mute or put it on external speaker settings,,k
Oct 24, 2010 | LG Flatron L1740BQ 17" LCD Monitor
Does the lg w2753v flatron have sound included? If so how do you turn it on?
The W2753v does not include speakers so it has no sound capabilities built in, you would need external speakers.
Oct 10, 2010 | LG W2753V PF Flat Panel 27" LCD monitor
LG Flatron L1951S-SN 19" LCD Flat Panel Monitor Logo
1,707 people viewed this question
Top LG Computers & Internet Experts
Ekse
Alun Cox
k24674
Are you a LG Computer and Internet Expert? Answer questions, earn points and help others
