Sony KP-51HW40 51" Rear Projection Television Logo
Posted on Dec 26, 2008
Can't find a front screen for Sony projection tv model # KP61565
The screen looks like an insert that evenly distributes the colors of the projection lens across the entire picture. We were moving it and ti blew out and cracked on the highway. If you know where to find this part and the name of the part I would appreciate it. Thanks.
Jose A Rodriguez
Level 1:
New Friend:
Problem Solver:
  • Contributor 1 Answer
  • Posted on Dec 05, 2014
Jose A Rodriguez
Contributor
Level 1:
New Friend:
Problem Solver:
Answers
Questions
0
Helped
102
Points
  • jose527 Dec 06, 2014
    www.PartStore.com
jose527
Level 1:
Problem Solver:
  • Contributor 2 Answers
  • Posted on Dec 26, 2008
jose527
Contributor
Level 1:
Problem Solver:
Answers
Questions
7
Helped
177
Points
3answers
Blue and green color outlines objects on screen
Projection TV sets have two very common problems. One is convergence ( 3D/Warped video) the other is CRT fluid ( Dull Video). Here are more details and solutions for both. Repair kits with instructions are also avail from www.TvRepairKits.com
Common Problem #1) Convergence has gone out
Projection TV sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the video to look normal. When its out of alignment the video will look 3D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the TV menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired.
This is a very common failure on these projection sets and a fairly simple DIY fix. All projection sets including Samsung, RCA, Sony, Philip Magnavox, Panasonic, Pioneer, Akai, GE, JVC, Toshiba, and others at some point will have the same problem.
Common Symptoms include....
  • Screen looks 3D
  • Colors don't line up
  • One or more colors can't be adjusted when using the convergence menu.
  • Screen is bowed or warped.
  • TV shuts off after powering on. Power light will blink. TV may also make a chirping noise.
Here are some pics of convergence problems.
69189a5.pngSOLUTION #1
For more more examples and find a fix using this link on Fixya http://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Common Problem #2) CRT Fluid is Cloudy
Projection TV tubes have a liquid coolant that is used to keep them from overheating. After many years the coolant in the blue and green tubes will become cloudy and cause the screen to look dull, red/orange, etc. You may even see halos around images.
Picture of a set that needs the fluid changed.
TV set after fluid change
69189a5.pngSOLUTION
You can see some more examples and find a fix using this link on Fixya http://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Last night we got some multicolor, green, yellow etc horizontal, kind of half moon shapes coming across the screen, removed the front screen and cleaned the lens's and mirror,, no change. Any Ideas?...
All projection TV sets have two very common problems. One is convergence ( 3D/Warped video) the other is CRT fluid ( Dull Video). Here are more details and solutions for both.
  • Screen looks 3D
69189a5.pngSOLUTION
Screen turns red then shuts off
Sounds like a bad red projection tube, disconnect red tube socket and try again if tv stays on reconnect tube soket and adjust screen controls on front of tv under the front panel which you will have to remove to do any of this. There are six adjustment controls 3 are for focus for each color and 3 screen controls for each color. Look close at the black plastic control module should be labled R G B for focus and R G B for screens. Good Luck!
Mike
The screen looks faded. The colors are right, but
take off the front of the set, and clean the lens as well as the mirrors inside the tv set
Techman
The screen is redish in color and the sound doesn't work!
This link has the instructions on how to fix this problem and other similar problems. You
have nothing to lose, so I recommend that you try it.
http://www.somelifeblog.com/2007/06/sony-projection-tv-red-line-repair.html
This works with the two other colors, blue and green also. Not all models of Sony Projection
TVs have the red, green, and blue pots in the same order as the picture that is listed on
this link, so you may want to google search for your model's service manual. The service
manual can also help you be able to remove the cover for your particular model of TV. I was
able to find the service manual for my model, and sure enough, the order of the pots are
reversed on mine, so I would have been adjusting the wrong color. Read all of the comments
on this link too, because you can find other helpful tips and may even find someone with the
same model of TV as you that gives more specific instructions for your model.
You may also find your model's service manual here:
http://esupport.sony.com/US/perl/index.pl
You can find information on Sony blink codes here:
http://www.somelifeblog.com/2007/08/sony-tv-led-blinking-codes-what-does-it.html
Blurry picture/adjust convergence
http://www.kb.sony.com/selfservice/documentLink.do?externalId=C426085
I hope this helps you!
Fare well. :)
Iconoclast
P.S. You can also clean the mirrors and dry dust while you're in there which can help with blurriness and focus.
Sony projection tv model kp53v80
Projection TV sets are known to have two common problems. The first problem that is common to these sets is convergence failure. When this happens the TV will usually look 3D, Wavy/Distorted, etc. It may also shutdown and blink an error code.
The second common problem with Projection TV sets is dull video, halos around objects, white looking video, or red overpowers the screen. This is commonly caused by the fluid in the lens being clouded overs.
You can find more details and solutions here on Fixya at the following link below. Or click HERE
3d884ac.pnghttp://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Can't find screen part for sony rear projection tv Model# KP61565
1 is called a lenticular and the other is called a freznel usually expensive.
Concave TV screen
your tv needs to be looked at by a professional tech..it may need reconverged..
1helpful
Sony kp57hw40
Reset RGB screen controls....located behind lower front speaker
grill & access cover.....turn down ( CCW ) green screen slightly
and other two colors as needed.....T.
Sony TV Screen
Is you model listed below?
Sony wega blue dot or star pattern on screen
http://esupport.sony.com/perl/news-item.pl?news_id=206&mdl=KDF42WE655
Models: KDF-42WE655, KDF-50WE655, KDF-55WF655, KDF-60WF655, KDF-55XS955, KDF-60XS955, KF-42WE620, and KF-50WE620
Top Sony Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
ZJ Limited
ZJ Limited
matt martin
matt martin
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
