SOURCE: Program a universal remote for the Dynex 32" 720p Flat Panel
Try using the codes listed for Orion products. Worked for me.
SOURCE: TV screen went negative. Brand new TV
I would use the warranty for this problem. The part that need to be replaced can be somewhat expensive.
With the credit card statement, you can use that as a receipt.
SOURCE: Dynex remote sticks on channels and does not always lower volume
I think you'll find that the tv is at fault. I, unfortunately bought one of these **** things as well. If you try to turn the channel, or volume, at the tv itself, you'll find that it won't work either. Seems to happen when switching between HD and regular programming a lot, but can happen at any time. You get what you ( and I ) paid for....
Testimonial: "I believe this person is right. I thought it was the remote control but it is the Dynex tv itself"
SOURCE: TV worked fine one night, next day screen is white.
The LCD Panel failed. There is no easy fix but try to get the T-Con board to fix the issue. However, this part is usually only available with the whole LCD Panel. This is usually the most expensive part in the TV and the whole TV needs to be taken apart to replace the panel.
Might be economically viable if you can find a place that carrys the T-con but Dynex parts are usually hard to find. The LCD Panel part alone will exceed the cost of the TV.
SOURCE: I purchased my Dynex 26(?) late june, and fine
Bad power supply,Hard to find,They went out of business. may try to find a remanufact,or used from Shop jimmy,or even Ebay. Encompass does not have them. This is why I recomend Extended warenty. I handel all of central FL.Best buy was giving a trade in for another brand TV. If you get rude enough,They might let you return it. Trust me is works often.
