C-6000
Your fuser tripped an error flag. Try power cycling the machine. If that does not work then press the button to check job status and enter 10871087. You might be able to enter that code from the copy screen. In any case lets continue, you enter that code and then screen changes. You then enter 906... That is a general reset. You could also try 163 that is a fuser reset. If neither one works then you need a new fuser unit
in many cases, the cause of fuser failure is not using oem toner.
kyocera task alfa 180 oem toner
I’m happy to assist further over the phone at https://www.6ya.com/expert/norman_d2fa496dce30c65d
thank you its work
