It only shows black screen after turn it on, there is nothing appearing except sign of SAMSUNG and buzz every other 5secs. I can't turn it off easily, have to take the battery out instead. Connected with laptop and again shows nothing on both. I think I may deleted some important part by mistake, is it possible to re-download to repair it by myself? Please give me your advise, it will be very helpful. Thank you!
SOURCE: Samsung SCH S259 mobile driver to connect to laptop
Hi,My phone is CDMA Samsung S259 problem is Phone locked Please contact service center
Plz any solution,Plz help me..Thanks
SOURCE: Samsung 740N blank screen
That sounds like a capacitor or maybe a mosfet died. Usually only capacitors 'sing'.
first you need to confirm it is the backlight section that died. simple visual inspection. You want the monitor plugged into a running booted computer. If you have anything that will do dual screen that lets you know what and where something should be on the screen being tested.If not anything will work. Let the computer boot up and then you will need to get close and near an edge. What you are looking for is a ghost image of the normal desktop. You may even be able to see the mouse move around. This is the actual picture produced by the lcd. It is very faint. The backlight acts somehwat like a projector bulb and shines through the lcd panel. So if you can see anything then your backlight or the backlight power are the problem. I'm in BC so its hard to reccomend any place for parts. Most of the ones I have fixed the parts were out of California.Cost should be about $70-$100.
If the backlight isn't the problem then it is usually a power section problem. The parts are cheap but the time to find the bad one can cost a bit. If you can find a place to fix it get an estimate. Then check out the replacement price of a new monitor. The prices have dropped and sometimes it isn;t cost effective to repair even a backlight on some models.
Testimonial: "Sounds like he went right to the problem. I think I can take it from here. "
SOURCE: When phone is turned on, the screen showing
hi,
your phone software crashes or corrupted. we can do nothing about it unless we have a special gadget used to fix mobile phones and buying it cost so much for that purpose only.
To save time and money, I recommend to have it reformat at your nearest service center or dealer if it still has the warranty or to trusted mobile phone repair shop.
Hope I helped you in some other ways.
Don't forget to rate me. Thanks...
Best regards,
John
Testimonial: "Thank you bigjohn007 for the solution. I will have my phone checked..."
SOURCE: I have the samsung 2232gw
There's a good chance you have failing electrolytic capacitors either in the power section or the inverter section or both.
Any caps in these sections that look bulged at the top, or bulged/leaking at the bottom need to be replaced.
If you repeatedly turn it off and on, eventually it'll probably stay on, but every time you turn it off, the TV will get harder and harder to start up until one day it just won't.
Sometimes you have to do the opposite to start it up and unplug it for some time and then try again.
If you aren't tech savvy, don't worry, read the rest of this solution and watch the videos.
If you are handy with a soldering iron and can identify the power supply and inverter / FM section for the backlights, an inexpensive handful of capacitors will likely fix you right up.
Match the capacitance on the capacitors. Go over voltage if you can, and still have them fit.
IE - it's not a bad idea to replace a 10V cap with a 16V or 25V or even a 50V, but don't replace a 680uF cap with a 500uF or a 1000uF (unless you are positive it's only doing ripple filtering, and even then, you should go OVER, not under the uF rating).
Most of the caps that go are 10V 1000uF or 3300uF.
I found some great videos of the procedure (for many Samsungs with the same issue) on youtube.
http://www.youtube.com/watch?v=Mm51C_RDIZE
http://www.youtube.com/watch?v=BNHHrgX_6cs&feature=related
http://www.youtube.com/watch?v=8l0AUj8QUkg&NR=1&feature=fvwp
http://www.youtube.com/watch?v=Y7b_nTaZYcU&feature=related
As you can see, this issue spans plasma TVs, as well as large and small LCD TVs and monitors.
The parts are cheap, and skill required is minimal.
Testimonial: "This will help out. Thank you very much."
The blue screen is known as the screen of death for a reason. You can try getting it fixed but most likely you'll need to replace it.
