Question about Canon imageCLASS® MF4150 All-In-One Laser Printer
My printer MF4122 shows Toner is not set. Insert Toner. means what?
    Sergeant:
  • 241 Answers
Believe it or not this error normally relates to the paper tray. Take all of the paper out of the tray and then reinsert the paper into the tray.
Hope this helps.
Posted on Sep 14, 2012
6ya staff
SOURCE:
Anonymous
  • 22 Answers
SOURCE: CANON MF6550
The error you are describing is usually cause by a bad cartridge but if you have tried a new Canon cartridge because refills will cause this a lot then we would need to look internally. If you look inside the unit (cartridge removed) on the right hand side towards the bottom you will see 3 flat metal plates. These are called spring plates when you push on them they should move in and out check and make sure they are not bent or depressed in you can try and use your fingers to fix them if they are. If not this unit would still be under the 3 year manufacture warranty call Canon they should give you service options. 800-828-4040
Posted on Jan 29, 2009
Anonymous
  • 83 Answers
SOURCE: Toner is not set Insert toner. Toner is set.
toner is like the catridge.. i think yu ve an laser printr.. yur toner is removed or else loose.. yu shd fix tat problm... by checkin yur toner.
Posted on Jul 06, 2009
Anonymous
  • 16 Answers
SOURCE: my printer canon imageclass MF4122
1- open the glass scaner
2- now clean the steel shift and the in the end shift you can see white plastic roller clean it by oil cleaner then but on it white greze let the greze be between the slote of the white roller tobe move good
3- another side of the shift you have amotor and tow plastice dishly clean it then but a greze on it noite not put mor grezs
4- now clean the glass scaner and teste your printer
if it's still in problem try whith this step
1- open glass of the scaner then you have white cable it's between the scaner lamp and logic change it and teste your brinter
if it's still in problem do it's end step and you will finish the problem
change the scaner lamp and not forget clean the stel shift in the begining when you clean the white roller and put on the steel shift a white greze
good luck
basher66 - Iraq- Ramadi -
Posted on Nov 29, 2009
Anonymous
SOURCE: Canon imageclass mf4122 showing errow E225
Posted on Mar 09, 2010
Daniel S
Daniel Scott
  • 4323 Answers
SOURCE: when I power on my
Hi
Error e225 on Canon MF4122 appears due to a loose gear or a mechanical problem with the device. However, this error may also appear due to firmware error. You'll need to update the firmware to resolve the issue. Download the firmware from this link---
Canon imageclass printer error e225 firmware
Also try looking for a broken gear and/or loose wiring inside the printer. Hope this helps... If it does please do not forget to accept the solution or post back for assistance.
Daniel
Posted on Sep 18, 2010
Toner error
With very few exceptions, modernprinters need a full set of cartridges to even try and print.
the reasons for this are not quite an sinister as you may think. Many printers use a little colour and them finally apply black to create a very deep shade of black. printers also periodically do small cleans, checks and calibrations to keep the printer running as efficiently as possible. In order for many of these to be performed they need a cartridge of each colour to avoid damage etc.
Feb 27, 2014 | Konica Minolta PagePro Office Equipment &...
HOW CAN I SOLVE "THE TONER IS NOT SET INSERT THE TONER" ERROR ON MF3220 CANON, I've checked the sensor and cartridge gears.
TAke out the cartridge and unplug it and plug it back in and put the cartridge back in and see if thats the problem for you.
Dec 29, 2012 | Office Equipment & Supplies
How come my Canon ImageClass MF4122 printer gives fuzzy images?
That is best bet since it appears that your print head is fubar and Canon charges a fortune for them. Cheaper to get a new printer with warranty.
Aug 24, 2017 | Canon New Compatible Black Print Laser Ink...
Problem with the Sharp -COPIERS - AR165 Call servis F2-04
Hi, this is a problem to do with the toner cartridge.
Answer
  • Try to remove it out and re-insert it.
  • Replace the compatible toner sensor with the old one.
  • Please use Ar 202ft original toner cartridge which fits this machine.
  • Your problem is now solved good times.
Nov 22, 2010 | Sharp AR-5316 Advanced Digital Imager...
Need printer driver for canon imageclass mf 4122
Open http://www.canon.com.sg/p/EN/39-All-In-One/104-Laser/4-imageCLASS-MF4122/ Click on support and download drivers.
May 27, 2010 | Canon imageCLASS MF4150 All-In-One Laser...
Jul 06, 2009 | Canon imageCLASS MF4150 All-In-One Laser...
Toner replacement
When this happens it is usually because the paper has misfeed remove paper from cassette tray replace it then reseat toner.
Jan 03, 2008 | Canon imageCLASS® MF4150 All-In-One Laser...
Canon imageCLASS® MF4150 All-In-One Laser Printer Logo
189 people viewed this question
Clive
Clive
old marine
old marine
Ekse
