OS: XP service Pack 3 Printer name : HP Officejet 5610 Motherboard model: DG31PR
SOURCE: HP deskjet 1120c professional serias printer
I have the same Printer and it works great in Windows XP Pro, so maybe you need to check their website for updated printer drivers...? My Printer is the HP Deskjet 1120C Professional Series Printer, that's the full name so I guess its the same printer...can print up to 13x19 inches....I've used the heck out of mine and it just now developed a problem where it won't pull the paper in from the front, but believe it or not I can load one sheet at a time from the back....
SOURCE: HP Photosmart 4400 Series will not install properly
Go here to download the driver. you should beadle to get it installed right here.
http://h10025.www1.hp.com/ewfrf/wc/product?product=3418705&lc=en&cc=us&dlc=en&submit.y=11&submit.x=4&lang=en&cc=us&y=2&x=7
Good Luck and Please Rate FixYa!
SOURCE: Windows XP SP3 doesn't recognize HP 1020
Check in control panel/device manager and see if there are any red or
yellow exclamation marks and while there see if your USB is installed
and if find problem contact us at our tollfree no 18884276640
SOURCE: Scanner error in HP officejet Pro L7590
These instructions will fix the majority of scanner problems and networking problems using ethernet:
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c01849855&lc=en&dlc=ro&cc=ro&product=3643612&rule=4124&lang=ro
The key is to assign a static ip address for the printer. The install problems of trying to get the HP printer to be found will go away. You can then use the scanner. Also...it is crucial that when connecting other laptop's and PC's on the same network that you use the hp printer'rs host name to find the printer on the network. I find that the IP address can and usually fails to find the hp on the network. Mostly likely you cannot search the network for a hp printer until you go the route of find the hp network printer with the host name of the printer. You will also need your install disk when installing on other networl laptop's and PC's since windows xp and Vista machines don't have the drivers in the list. You will need to point the add printer gui driver to the disk and look for autorun.inf
file. After selecting that file...you can then see your drivers.
