I have 2 users on my pc and im the admin for it but ive forgotten my password to login to my account and i can not install anything from the other users because they do not have the auth to do it. need help to reset password or delete that user
Follow the below steps to enable Windows XP built-in administrator account:
Now the super administrator account is successfully enabled.
Next, you can easily reset the forgotten XP password from
"Start->Control Panel".
If the above method can not help you, you can use Smartkey Windows Password Recovery to help you to reset windows xp administrator password, and see the detail direction from http://www.recoverlostpassword.com/products/windowspasswordrecovery.html
SOURCE: Admin account on Vista pc locked out, forgot admin password
Step 1
START THE COMPUTER. DO THIS BY PRESSING THE POWER BUTTON. DO NOT WAIT UNTIL WINDOW LOADS TO PERFORM STEP 2.
Step 2
PRESS F8 KEY ***BEFORE*** WINDOWS VISTA BEGINS START UP. THIS WILL PROVIDE A LIST OF OPTIONS FOR HOW TO PROCEED.
Step 3
CHOOSE TO START YOUR COMPUTER IN "SAFE MODE".
Step 4
OPEN THE START MENU.
Step 5
OPEN THE CONTROL PANEL (from within the Start Menu).
Step 6
SELECT "USER ACCOUNTS AND FAMILY SAFETY" IN THE CONTROL PANEL POP-UP WINDOW.
Step 7
CLICK THE "CHANGE YOUR WINDOWS PASSWORD" LINK BENEATH THE "USER ACCOUNTS" SECTION.
Step 8
CLICK "REMOVE PASSWORD". VERIFY AND SUBMIT.
Step 9
RESTART YOUR COMPUTER NORMALLY. DO NOT PRESS F8.
Step 10
TO RESET A PASSWORD, ACCESS THE "USER ACCOUNTS AND FAMILY SAFETY" MENU AGAIN. THIS TIME CLICK "CHANGE YOUR WINDOWS PASSWORD", PROVIDE THE DESIRED PASSWORD, VERIFY AND SUBMIT. THIS TIME, WRITE YOUR PASSWORD DOWN.
If this helps please rate me. thanks
SOURCE: forgot my xp login user acct password for emachine
You can use Hiren's Boot CD: http://www.hirensbootcd.net/download.html?ver=11.1
SOURCE: I forgot my emachines pc password, How do i get
You can change your passwordusing your standard user,how?
Please follow the step:
1. Click Start, and thenclick Run.
2. In the Open box, type "mmc" (without the quotation marks), andthen click OK to start MMC.
3. Start the Local Users and Groups snap-in.
4. Under Console Root, expand "Local Users and Groups", and thenclick Users.
5. In the right pane, right-click Administrator, and then click Set Password.
6. Click Proceed in the message box that appears.
7. Type and confirm the new password in the appropriate boxes, and then clickOK.
SOURCE: i forgot me password on
I know a windows password reset tool is good Windows Password Reset 9.0 at http://www.reset-windows-password.com
SOURCE: If you lost windows password, you can go into safe
When I lost my windows password, I asked my friend David who is an IT engieer for help.
He told me use the windows password reset tool is the fastest and easiset way, and he recommend me use a tool called Windows Password Reset.
I download it and install . Then follow the official website instruction step by step.Oh,just need 3 steps and a few minutes, I reset my lock windows password. How easy it is !
Bypass eMachines password with recovery disks created before lost eMachine password
When input an incorrect password at the login screen, click "Reset Windows Password" and insert the eMachine password reset disk. The Password Reset Wizard will lead us create a new password to remove forgotten eMachines Windows 7 password.
Retrieve eMachine Windows password by DIY a password reset disk after forgotten
It is considered as the most instantly and easiest way to recover lost eMachine password. A .iso file, bootable CD/DVD/USB disk and accessible PC will solve problem within minutes without special techniques for a green hand on PC.
We can get the .iso file from many Windows password recovery programs. Just take one of the most popular tool - Ainorsoft Windows Password Recovery as example.
A. Download the suitable Ainorsoft Windows Password Recovery program and burn its .iso file into a blank CD/DVD or USB Flash Drive on an accessible computer;
B. Boot the burned CD/DVD or USB Flash Drive from the PC password locked;
C. Reset the new eMachines password.
Ainorsoft Windows Password Recovery tool concludes Basic, Enhance and Corporation versions. The Basic is opted for Windows 7, XP, Vista, 2008, 2003,etc. CD/DVD disk suits for it! The Enhance version can be used with USB disk for the former OS. While, the Ainorsoft Windows Password Recovery Corporation is designed to Windows 7/Vista/XP/2000/NT/Server 2008/2003/2000 with bootable CD/DVD or USB Flash Drive.
Main methods on eMachine password reset are shared as above. Recover forgotten eMachine laptop password from Safe Mode or unlock eMachines password with password reset disk. Hope the any one help our eMachines computer users!
Article source: http://windowspasswordrecovery.net/article/emachines-password-reset.html
