Do remove the flag from a photo delete the keyword "Flagged" in the Info panel for the photo. If you want to flag other photos, enter the keyword "Flagged" in the Info panel or from the Keywords Manager.
These instructions show two ways to reset the toner count ( to install a used toner in printer or get more life out of a cartridge the printer says is empty)
please note that using refilled toner cartridges, non genuine toners and using the 'extra' 10% all have been shown to reduce drum life and prematurely degrade print quality.
you may need these techniques though if you have tried a new toner in a machine to diagnose and then want to install it in another machine.
The first method is to reset the mechanical flag on the left hand end of the toner cartridge. when you first install a toner the printer turns the toner drive gear which moves this flag from the back to the forward position (towards the toner roller).
the flag is the white rectangular bit pointed out by the yellow arrow in the photo
In this photo the position of the flag shows that this cartridge has been previously installed in a printer.
you can undo three screws (red arrows in photo) and reposition the flag in the start position.
be careful to observe the way the gears are installed.
one technician I know just used a flat blade screwdriver to force the flag back to its home position ( to the right) without undoing the screws. seemed to work for him.
the second method is to
1. open the toner door
2. turn printer off
3. hold down go button
4. turn on power while holding go
5. hold down go button for 4-5 seconds untill all lights come on and one goes out
6. press go twice then wait 2 seconds
press go 5 times
printer should power cycle and show itself as ready
Twitter has a strict privacy agreement with everyone that creates an account in which they follow faithfully unless they are ordered by the court to release private information. You can flag that page so that they can shut the page down.
JAM IN TOP COVER AREA A jam exists in the top-cover area. A 13.20.00 error message indicates that the printer power was turned on or that the printer attempted to initialize while the pre-feed sensor (PS102), the top of page sensor (PS102) and/or the fuser delivery sensor (PS108) was detecting media.
When the paper feed assembly is installed, the sensor-flag spring must be correctly positioned for the flag to operate. If a paper-jam error message (13.20.00 JAM) appears on the control-panel display after you replace the paper feed assembly, verify that this sensor-flag spring is installed correctly. Hook the spring over the flag tab (see 1 in Figure). Fasten the paper feed assembly to the chassis with the flag spring positioned in the hole in the transfer assembly. Release the spring from the tab on the flag (see 2 in Figure). See figure below. Verify that the flag is held in the upright position, can freely move, and always returns to the upright position. If the flag does not move freely, or return to the upright position, an error message (13.20.00 JAM) will appear on the control-panel display when the printer power is turned on.
Al13nwa4re5acasE - Alienware Symbol Alienwarec8pestU - Alienware Black Dog tags AMD3afrUnap - VISION square tag (red) 4MDB4quprex - VISION square tag (blue) AT1hAqup7Su - ATi square tag. E3F6crAS5u - Grey/Orange Dog tags Denek1Ju3aceH7 - Yellow Teddy Bear Fam1tsuprusWe2e - Tag with ingraved-writing/picture. Bl4ckl1ght2Ru7uS - Couldn't get to work. Ch1pBLuS9PR - Blacklight logo chip. Ch1p1GN1u0S - Lighting bolt chip. Ch1pMMRSc0rp - Blacklight "W" logo chip. Ch1p0RD3Ru02 - Order logo chip. Ch1pZ0MB1Et7 - Zombie Studios logo chip. H4rtBr34kerio4u - Pink Brass Knuckles. SKULLCLUB9rAVaZ2 - blue skull square tag. J4ceH4llstuFaCh4 - Couldn't get to work. StormLion9rAVaZ2 - Dinosaur thingy?? St0rmLi0nB4qupre - Dinosaur thingy?? tag. R4z3erzu8habuC - green and black tag. UPGr0undWupraf4u - Black square tag with design. UPGr0undv2FUDame - Black square tag with design. AUS9eT5edru - Australian Flag AUTF6crAS5u - Austria Flag BELS7utHAsP - Belgium Flag(?) CANfeprUtr5 - Canada Flag DENdathe8HU - Denmark Flag FINw3uthEfe - Finland Flag FRApRUyUT4a - France Flag GERtRE4a4eS - Germany Flag HOKYeQuKuw3 - ??? INDs4u8RApr - India Flag IRE8ruGejec - Ireland Flag ITAQ7Swu9re - Italian Flag JPNj7fazebR - Japanese Flag KORpaphA9uK - Korean Flag MEX5Usw2YAd - Mexico Flag HOLb8e6UWuh - Holland Flag NZLxut32eSA - New Zealand Flag NOR3Waga8wa - Norweigien Flag PORQ54aFrEY - ??? R41nB0wu7p3 - ??? RUS7rusteXe - ??? SINvuS8E2aC - ??? ESPChE4At5p - ??? SWEt2aPHutr - Sweden Flag SWIsTE8tafU - ??? TAW8udukUP2 - ??? UKv4D3phed - United Kingdom Flag USAM3spudre - United States Flag
I would flag the photos. You do this by selecting a photo and then
using the command under the photo menu or on the iphoto dock. Once you
have flagged the photos you want to delete, go to the flagged items
under the library and then select all and then hit the delete key. Hope
this helps
There are two ways the progress of a sheet through the machine are monitored; either photoelectronically or via a 'flag' that is pushed out of the way by the paper as it progresses through the machine.
These flags also use photo sensing but if a flag is broken by someone stabbing stuff into the paper path (seen a lot of that), the flag won't reach the paper so the machine thinks there is a jam.
Is this a new problem or has it always been like this? The unit will throw that error message if there's a copy protection flag on the broadcast source.
To make matters worse, there are three flags a broadcaster can set. Copy Always, Copy Once, and Copy Never.
Copy Always and Copy Never are pretty self-explanatory but the Copy Once flag with this unit only works with certain media, namely DVD-RAM and DVD-RW in VR mode with CPRM (Content Protection for Recordable Media.
Copy Always flag should work with all media. I don't know of any easy way to figure out which broadcasts have which flag but try changing your media and recording mode first.
P.S. You may also want to reset to factory default settings by pressing FF and RW together on the player. Also make sure you're running the latest firmware.
