When i connect nokia 5130-c2 phone in usb post when msg prompt usb device not recognized also I installed nokia pc suit latest and if I connect other usb port same mobile then it will connect when i restart pc then same error msg shown in other usb port not I have inserted all usb ports my mobile so what can i do.
SOURCE: Nokia 6233 GPRS connctivity through USB blue tooth dongle and Nokia PC suite
There is some problem in your Bluetooth device driver. Try to uninstall it and restart your Pc then reinstall it.
SOURCE: i have nokia xpress music 5130 and it gives me
I myself own this awesome music phone.
Find the answers below:
1) As it shows less internal memory, it seems that you have transfered some data like mp3, video clips through bluetooth to this phone and it was saved in the recieved folder which autmatically saves in phone memory. Try saving the data to memory card and you will get the phone memory free.
2) Check the above reason for this same issue.
3) You need to select proper connectivity mode under settings of this phone. Go to settings and then open connectivity folder. Here select the connection mode.
Make sure to install the latest PC suite software on the computer. This can be downloaded from the NOKIA website.
Regards
Anand
Rate it, if it helps.
SOURCE: Nokia 6500 slide. Device Not Recognized
If you go to Control Panel -> System -> HardWare and check USB controllers which shud give you a list of all USB ports. Below that you will find Wireless Communication Devices. In this you shud find all the modes your phone is installed as. Check if all these settings are present. Secondly, install PC Suite now that you have restores the system to an earlier date. Connect the phone and connect.
SOURCE: my phone not connect by pc suit software
there are four solutions,
1-select offline mode
2-check the data cable
3-format your memory card(because there might be virous)
4-update your phone software using mobile internet
SOURCE: my nokia 5130c is not supporting nokia pc suite
Not able to connect ur phone. Thats Wierd.
well connect ur data cable to pc & phone. when u do so, u'll get options on ur phone like
1. PC Suite Service
2. Mass Storage & all..
select PC suit service & then its done.
but for PC suite service, u need nokia pc suit on ur pc too..
