SOURCE: Changing result display from fractions to decimals
Struggled with this and found answer on about page 19 of the instructions on the Internet. Answer also appear on paper instructions under: "Displaying Calculation Results...etc just under "Note" Trick is you must have calculator in "LineIO" mode For setting MODE see "Calculation Modes & cal. Setup in paper instructions.
SOURCE: changing fractions to decimals
pressing the 'a b/c' key toggles between fraction and decimal formats
SOURCE: my calculator won't give me decimal numbers
Use the [S<->D] key to switch between the two.
Hope it helps.
SOURCE: fractions to decimals?
To change the displayed result from fraction format to decimal, press the [S<->D] key.
You can also configure the calculator to be in LineIO mode. In this mode, all results are in decimal format.
To set the LineIO mode , press [SHIFT][MODE][2:LineIO]
Hope it helps.
SOURCE: how do I change my
To convert a single result from fraction to decimal, press SD. To have all results come out in decimal, press SHIFT MODE 2 to select LineIO mode.
Since there are 16 digits in 9676244435451234, the very last digit is the "10000000000000000th" decimal place.
So we can just say that .9676244435451234 is the same as 9676244435451234/10000000000000000.
We can reduce this fraction to lowest
terms by dividing both the numerator and denominator by -2.14748e+09.
Why divide by -2.14748e+09? -2.14748e+09 is the Greatest Common Divisor (GCD)
or Greatest Common Factor (GCF) of the numbers 9.67624e+15 and 1e+16.
So, this fraction reduced to lowest terms is
