Question about Epson Expression Home XP-200 Wireless All-in-One Color Inkjet Printer, Copier, Scanner C11CC48201
My epson xp-200 printer with won't print with the recommended ink cartridge epson 200. why?
I replaced it with what should work, and it says that the ink is not compatible, however in fits perfectly! why??
  • Epson Master
  • 32,281 Answers
The printer may only work with Epson ink cartridges and not compatible ink cartridges.
Posted on Sep 16, 2012
6ya staff
SOURCE:
websnail
Martin Smallridge
  • 419 Answers
SOURCE: Epson DX7450 won t charge ink
In some cases the chip on the cartridge will work for multiple models but this doesn't always mean that ALL cartridge colours will be the same.
It sounds like you either have the wrong magenta type or you have a cartridge which is incompatible. I'd look for a supplier that can confirm 100% that they have the correct chip for your printer and try that.
I should warn you that you may find that fixing the magenta provides you with a warning on a different cartridge as sometimes the chips interact with the printer in rather odd ways that give false positives or error indicators.. So be prepared.
Hope this helps somewhat.
Posted on Mar 25, 2009
websnail
Martin Smallridge
  • 419 Answers
SOURCE: Epson SX200 refuses to recognise compatible cartridges
Hi Howard,
Bottom line, if the printer doesn't accept them, then they are not compatible... I'd recommend returning them for a refund and find a supplier that has tried and tested cartridges.
I'd love to be able to recommend a supplier but as I don't have an SX200 I can't... Others might be able to help if you can indicate where you are in the world as the SX200 is, I believe, zone specific.
Best of luck
Posted on May 06, 2009
Anonymous
  • 163 Answers
SOURCE: epson stylus C88 won t print color ink black is
If you have carried out 4 to 5 head cleans, waited about 8 hours and done another 3 or head cleans doing nozzle checks after each clean (as recommended by the manual) and there is still no improvement then you will need a third party head cleaning solution such as this one:
http://websites.uk-plc.net/UK_Inkjet_Cartridges_PLUS/products/Print_Head_Cleaner.htm
Other makes & brands are available just google "inkjet head cleaning solution" Hope this helps.
Posted on Apr 03, 2009
Alun Cox
  • 2679 Answers
SOURCE: printer will not print in black ink. Epson stylus color 400
Try cleaning the print heads.
Posted on Jun 19, 2009
Anonymous
  • 30 Answers
SOURCE: Epson Ink Problem on sx200 printer
Fiend your solution direct from EPSON. Here is your solution...
http://www.epson.com/printer/prob676ijt65/solution
takio-28
Posted on Sep 04, 2009
Epson t60 is good printer ?
Hi global_sreek,
EPSON is Super fast, affordable & powerful for all your professional photo printing needs.
Features
Increase your productivity with super-fast print speed
• Print instantly from your computer screen at a fast print speed of 12 seconds per 4R photo
Maximise savings with Epson INKdividual™ Cartridges
• Maximise savings and minimise wastage by replacing only what you need
• Epson 6 colour photo ink is highly affordable, keeping daily running costs low
Perfect printing onto CDs / DVDs
• Print directly onto the printable surface of your CDs/DVDs
Compact size to fit any space
• The Epson Stylus® Photo T60 is so compact, it takes up little precious studio space,
freeing it for other uses
Photo perfection with Epson Creativity Suite
• A powerful photo editing software that lets you perfect your photo prints with just one
click of a button
SPECIFICATIONS
Print:
Ink System - 6-colour
Ink Type - Photo Dye(??¥?œ¬??ž?®??š??¼??¸????₪œ?´¢ )
Max. Print Resolution - 5760x1440 dpi (with VSDT)
Min. Ink Droplet size - 1.5pl
Print SpeeD - Approx. 37ppm (Black) Approx. 38ppm (Colour)
Connectivity and Compatibility:
PC-less function - No
Index Sheet - No
Connectivity - Card Slot - No
Connectivity - USB Cable - Yes
Connectivity - Wireless - No
Interfaces - USB 2.0 Hi-Speed
OS Support - Windows 2000/XP/XP-x64 Edition/Vista Mac OS 10.3.9 or later with USB
Network - No
Adobe Postscript - No
Memory Card Backup - No
Ink Cartridges:
INKdividual - Yes
Ink Cartridge Model - 85N Ink Series (Standard Capacity)
Media:
Media Model - S041926E1; S041927E1; S041863; S041464E1; S041285; S042070; S041925; S041332; S041786, S041259
Paper Handling:
Max. Paper Size - A4
BorderFree - Yes
Max. Paper Capacity - 120 sheets
Roll Paper - No
Tractor Feed - No
Cartridge Model(s):
85N (Standard Capacity Black Ink) - Approx 540 pages (ISO/IEC 24711 and 24712 Test Suite)
Page Yield (pages):
85N (Standard Capacity Colour Ink)* - Approx 860 pages (ISO/IEC 24711 and 24712 Test Suite)
Hope it helps.
Thank You for using Fixya.
Sep 07, 2011 | Epson TM-T60 Printer
Tip
Printer ink
New printers are putting microchips in them so you cant use compatable inks ,so make sure when you buy one that it definately accepts compatable ink or it will cost you a fortune , or you can take it to a computer shop and they will fit a microchip so it can accept compatable ink.
on Feb 02, 2011 | Office Equipment & Supplies
Which black ink cartridge is compatible with this printer as the one i have purchased using the same cartridge dode seems to be narrower than the original?
What manufacturer of printer?
What model of printer?
Generally, there are no "compatible" ink-cartridges (HP sometimes has "high-capacity" cartridges, as an alternate to their "regular" cartridges), unless you find an Asian company that makes "compatible" cartridges.
If the replacement fits, and the printer recognizes it, then use it.
Jun 20, 2011 | HP Office Equipment & Supplies
Ink not compatable on sx 400
Try pulling out the cartridges and powering down the printer. Put the cartridges back in and pull power back up. That may let the printer recognize them and sober up. If you have recently replaced the cartridges, make sure that the new ones are EXACTLY the same as the old ones. Even if they fit, they may not work.
Jul 20, 2010 | Epson Office Equipment & Supplies
Printer does not go
After few head cleaning, ink counter running low, so ink ligh (red) flashing. Then ink counter runing out, so the light stayed on. After replacing both of ink, red light stayed on, because the compatible ink (chip) not recognized by printer. Check epson status monitor. Use original ink or refill and reset ink level counter.
May 26, 2010 | Epson Stylus C60 InkJet Printer
Compatible ink cartridges dx8400
Epson cartridges are microchipped.
Do your new cartridges carry the same chip?
If not, they will not work.
If all else fails, return them to the supplier and explain they are not recognised by your printer.
Feb 18, 2009 | Epson CX8400 All-In-One InkJet Printer
Cannon MP600 error message U052
Hello all, I have had an MP600 for a few years now, and after paying about £50-£60 a set of inks i decided to use compatible ones and i also spent £20.00 on a ink resetter from Sudhaus http://www.patronenhandel.de/shop/en/Redsetter/MP-Serie/MP-600/mit-Refill-Set
After about a year of owning the MP600 i got the dreaded U052 error, so i went back to genuine inks, however this did not clear the error. i then decided to telephone Canon and they advised me to clean the print head thoroughly. If you look at the print head there is a white plate with 2 screws either side, i rmoved that CAREFULLY and cleaned behind it, i reinstalled everything back to normal and 2 years later i am still running perfect with no issues what so ever...I'm not sure what resolved the issue but i now refill my genuine cartridges myself and reset the chip with the Sudhaus resetter. To refill your cartridge use the tube inside the genuine ink cartridge DO NOT refill from the top, you will see the 2 arrows on the GENUINE ink cartridge pierce between there and use a long syringe to refill.
Hope this helps people in the future.
Jan 15, 2009 | Canon PIXMA MP600 all-In-One InkJet...
Poor photo printing
when the printer says that "for best results use Epson Ink." They mean it! otherwise using Xprint cartridges works as well, if changing the type of ink doesn't work then you might have to tinker with the advanced settings (you can change the amount of color used in the print) when you click the properties button in the print screen, ONLY if you know what you are doing!!
Oct 10, 2008 | Epson Stylus Photo R300 InkJet Printer
Ink cartidges
Without knowing where your "compatible " cartridges came from, it's difficult to say. The correct cartridge types for a 1290 are T007 and T009. Do your cartridges with lugs show these numbers? In general, compatible cartridges will fit into the cartridge carrier without problem. Yes, Epson did fit plastic key lugs to their cartridges to artificially make cartridge A different to cartridge B, when in reality they were identical e.g. C46 and C48. Now, compatible cartridges for your printer are incredibly cheap on E-Bay. My advice is just to throw away the troublesome luggy ones you have and buy some more on E-Bay - they will fit without trouble.
Feb 08, 2008 | Epson Stylus Photo 1290 InkJet Printer
Compatible ink
Hi, sounds like a faulty ink cartridge, we get this now and again with selling compatible ink cartridges i suggest taking it back to the shop for a replacement wont be the printer as long as its fitted correctly with label removed..
Happy New Year
John
Dec 17, 2007 | Epson Printer
Epson Expression Home XP-200 Wireless All-in-One Color Inkjet Printer, Copier, Scanner C11CC48201 Logo
2,227 people viewed this question
Top Epson Office Equipment & Supplies Experts
Alun Cox
Thomas F. Schneider
Ekse
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
