Samsung Galaxy Note N7000 16GB Unlocked QuadBand GPS HSDPA WiFi Cellular Phone White Logo
Anonymous Posted on Sep 16, 2012
Why the imei number erased from my galaxy nont gt-n7000 and how to restore it ?
For unknown reason the imei nomber erased from my galaxy note gt-n7000 . and this make the device only work as a pc and cant recognize any sim card and the phone function and all the phone function based programs not working
Anonymous
Level 2:
New Friend:
  • Expert 33 Answers
  • Posted on Sep 16, 2012
Anonymous
Expert
Level 2:
New Friend:
Answers
33
Questions
0
Helped
5106
Points
110
Try to do restore factory setting (Its risky yet...)
  • Anonymous Aug 09, 2013
    Did that but no effect. I am also no longer able to do any software upgrades
1helpful
Galaxy gt-n7000 keeps turning off
Hi there, my husband had the same issues with his Galaxy Note 4 and now it's ok after replacing the battery. You may need a new battery for your phone. Thanks.
Samsung Galaxy Note 4G is noy going to work unless it is unlocked
Hello. Do you want to unlock your Samsung Galaxy Note 4G from network restriction? If so, you can unlock it safer and easier using unique unlock code. You can get the unique unlock code for a Samsung Galaxy Note 4G from Unlock-Zone.com at affordable cost. Good luck.
.................UNLOCKING INSTRUCTIONS.................
Method 1:
1 - Switch ON your Samsung Galaxy Note 4G with a NOT ACCEPTED SIM Card.
2 - Samsung Galaxy Note 4G will ask for "Password".
3 - Enter the Unlock Code.
OR (if the Samsung Galaxy Note 4G shows "Insert Correct SIM Card")
Method 2:
2 - Don't bother about what's being displayed on your Samsung Galaxy Note 4G.
3 - Compose : #0111*CODE#.
5answers
Samsung galaxy note 2 unlock
Get the Factory Unlock code for Samsung Galaxy note 2
Here is the direct link to apply
Unlock Samsung How to Unlock Samsung Note -2
unlock - Any Cell Phones. Here the direct link to unlock any Samsung phone
Official Samsung IMEI Permanent Unlock Important Select the Current...
Aug 19, 2014 • Cell Phones
Galaxy note gt n7000
The best (but the most expensive) way is to contact your closest Samsung authorized dealer. Check the Google for this.
Jul 11, 2014 • Cameras
Will note n7000 get further android os updates
The only way to get 4.2.2 is this:
The first generation of the Galaxy Note line, N7000 initially runs Android 2.3.5 Gingerbread and later features Android 4.1 Jelly Bean. Owners of the device can update their Galaxy Note N7000 to Android 4.2.2 Jelly Bean with special features such as colour inversion, notification drawer, lock screen shortcuts and custom Quick Settings.
Using Slim Bean ROM, your Galaxy Note N7000 will run the latest Android 4.2.2 Jelly Bean containing all features of the Android OS, customisation and tweaking capabilities, amazing themes, stability, constant update and relatively bloat-ware free system.
Warning: Slim Bean ROM is a customised ROM and its developers are not liable for any damages on your device. The featured ROM only applies to Samsung Galaxy Note N7000 and should never be installed to any other devices. Read and follow the instructions carefully to prevent damaging your handset. Do this at your own risk.
Requirements:
Before you perform the installation, make sure that your device has met all prerequisites.
  • Your device must be rooted to be able to flash the custom ROM. Click one of the OS version for rooting instructions: Gingerbread 2.3.5 or Jelly Bean 4.1.2.
  • Create a backup of all your personal information, settings and data files on your device. Do not use Samsung Kies since Slim Bean ROM is a custom ROM which won't be detected by the program.
  • Uninstall all antivirus apps on your handset and temporarily disable any security programs on your computer. It may interfere the installation progress.
  • Make sure that the battery level is at least 50 per cent to prevent any power interruption during the installation.
  • Enable USB debugging mode on your device.
  • Install a custom recovery app such as ClockWorkMod recovery or TWRP.
  • Install USB drivers on your computer for the Galaxy Note N7000.
  • Download the Slim Bean Build 6 Android 4.2.2 ROM and the Slim Google Apps package on your computer.
Flashing Instructions
1. Connect your Samsung Galaxy Note N7000 to the computer via USB cable.
2. Copy the Slim Bean custom ROM and Slim Google Apps package to the external memory of your device. Do not extract any of them.
3. Disconnect your device from the computer then reboot it into Recovery mode using the custom recovery app.
4. Inside the Recovery mode, select "backup and restore > backup" to create a nAndroid backup of the current ROM which you can restore later in case of any problems.
5. After the backup, select "wipe data/factory reset" and "wipe cache partition" to clear all data on your device.
6. Then select "install zip from SD card > choose zip from SD card" and choose the Slim Bean ROM zip file to install it. Do the same with the Slim Google Apps zip file.
7. Once the installation is complete, go back then select "reboot system now." Boot up may take 5 minutes for its first run.
Congratulations! Your Samsung Galaxy Note N7000 is running Android 4.2.2 Jelly Bean using Slim Bean ROM with tons of other features not found on a regular stock ROM.
For any issues during the installation, send your feedbacks to the
Sim card not recognize
you may need a new sim card reader but more than likely your imei number has been erased....ive got the same problem. dial *#06# AND IF YOUR IMEI number isnt displayed then there is your problem. with out a clean IMEI number your phone is just a pc and will not connect to any mobile network, Downloading music can erase this or flashings.....
Samsung galaxy note hang up
i have samsung galaxy note 1 GT-N7000. and i have a problem in my cell,when my cell is open and it,s prepared network and prepared SD card and after that it hang.even that the touch system is hanged,pls tell me the salution,thank,s
1helpful
2answers
How to unlock my samsung note GT-N7000
You can get Unlock code for SAMSUNG N7000 from Prounlocking.com and unlock it from network lock easily..
What are the proxy and port settings for a samsung note
If you're using G3 network,
check Settings -> Wireless & Network -> More -> Networks -> Use Packet Data (activate Network) should be marked.
Top Samsung Cameras Experts
ZJ Limited
ZJ Limited
Are you a Samsung Camera Expert? Answer questions, earn points and help others
