The ice maker is working but the water dispenser is not working
SOURCE: Kenmore Refrigerator stopped dispensing water
Either your water tank in the fridge froze up, the waterline that goes up the freezer door from the bottom hinge froze, or the switch that your glass hits is damaged. Do you hear any humming or noises when you put your glass up to get water?
SOURCE: Kenmore Side by Side Refrigerator Ice Maker Not Working
A couple things to check here. First see if there is ice in the tray. If so chances are the ice maker will need to be replaced however these are very reliable ice makers. If no ice in the tray pull up on the ejector blade (don't worry you won't break it) turn clockwise to start the ice maker thru a cycle. The ejector blade is the long white bar with fingers on it that run the length of the tray. Once it completes a cycle it should fill with water. If no water then either the fill tube is frozen over and will need to be defrosted or the water valve is bad.
SOURCE: Kenmore elite (106.53606202) ice maker will not dispense ice
When you push the ice dispensing lever, you should be able to hear the micro-switch clicking. If no click, the switch is faulty. The auger motor which is activated by the lever could also be faulty. This is the motor that causes the auger in the ice bucket to rotate one way for crushed ice and the other way for cubes. The auger could also be jammed. Try switching between crushed and cubes to unjam the auger. Empty the ice bucket and start again.
SOURCE: Kenmore Coldspot Ice maker is not working on our side by side refrigerator
I have Kenmore Coldspot top freezer that is not making ice. I herad a clicking sound.
