How to send effects to microphones
You CAN'T send ANYTHING to microphones since they are INPUT devices.
If you want apply effects to the audio coming FROM them then this is what you do:
Adjust the trim and faders for normal use and verify the mics are working.
NOW for those mics you want to put effects on, turn the knob labled "FX" above EACH mic FADER that you want effects on... it will be the orange topped ones... about the fourth one up ablve the PAN and the two MON knobs. Adjust these to send each mic into the effects mixing buss. Start by setting them at 12 o'clock. You will use these to proportion the amount of effects applied to individual mics.
Next, advance the FX fader/slider to around the Unity mark... this controls the amount of the FX mix buss goes into the FX processor.
Next adjust the knob above the MAIN fader that says FX to Main. This controls the amount of the FX that is sent into the MAIN mix buss...
We are almost there... Select the effect you want with the effect knob to the number of the effect you want... it will be blinking AFTER a change... the effect will NOT have changed yet... WHEN you want the effect to take effect, PRESS DOWN on the effect knob and the effect number will stop blinking and you now have the effects on those mics... ADJUST the three level things... the knbs under each channel to proportion between the mics... adjust the FX fader for the USUAL control of effect amount... and finally the FX to main knb to set the limit of the effect going to the MAINS.
When push the defeat switch in the effects input clip led is on hard. This is probably normal. The effect defeat jack does the same as the push switch so every thing looks good here!
