You could try hard resetting it, just unplug it from the PC and power for 10 minutes then turn it back on. Read more here: Brother mfc 5890cn manual
Code 36
SOURCE: How to change Brother MFC 5890CN Language
Please follow the instructions below to change the language to English.
1. Turn off the machine
2. Hold in the MENU button.
3. Turn on the machine while holding the menu button
4. Maintenance should come up onscreen and the lights should flash.
5. Key in the numbers 74 and press Mono Start button.
6. Key in 0004 and press Mono Start button.
7. "MAINTENANCE" appears again on the display.
8. Key in 99 at the maintenance prompt to exit to the date and time
It should be now in English.
SOURCE: I have a brother MFC 5890CN printer and the yellow
It may be worth changing them again, you can on the odd occasion get a couple of duffers.
i would start afresh & do a head clean then a print test with a brand new set in.
If you get a perfect set of squares as the screen shows then its done if not repeat the head cleaning process untill you do, once you got those squares right your done.
SOURCE: have the brother mfc-5890cn having fax issues
Can you hear the receiving fax pick up the line? If so, you may need to slow the speed of your fax modem to allow for poor line conditions. You can find the instructions on page 12 of the Users Guide. If you don't have one, you can download a PDF file of the guide on the Brother web site.
SOURCE: Brother MFC-5890CN Printer
It sounds like your print heads may need cleaning. However, here is the link from Brother support for your MFC-5890CN on how to improve print quality:
Brother MFC 5890 Print Quality
SOURCE: Brother MFC-5890CN Adf Pulls In Two Sheets AT ONCE
Hi there
This is maybe the paper beed standing some where cold, so try and keep the paper packes in a worm place and when you put paper into the printer gave it a good shake first.
All the best Pineworks
