My S 301 does not work any more. When I put it on, the on/standby butten starts to flash blue. And the screen stays black, nothing works
SOURCE: Standby light is on but will not power,just keeps
Try disconnecting everything from the Denon including the power. Leave it off all night. Next morning plug in the power only and see if it will come up ok. Then power down (into standby), connect the other stuff and power on.
Hi
Press and hold the HEATED DRY/NO HEAT DRY/AIR DRY button for
15 seconds to unlock the control lock in your dishwasher. Also make sure that
nothing is blocking the drain pump assembly. If the issue returns after its
cleaned then it means that the control board has gone bad and should be
replaced. Hope this helps...please post back for further assistance.
Daniel
Resetting the main unit
Use this procedure to reset all the receiver's settings to the factory default. Use the front
panel controls to do this.
1 Switch the receiver into standby.
2 While holding down the TONE button, press and hold the STANDBY/ON button for about three seconds.
3 When you see RESET? appear in the display, press ENTER .
OK? shows in the display.
4 Press SYSTEM SETUP to confirm.
OK appears in the display to indicate that the receiver has been reset to the factory default
settings.
