I wanted to know what the largest size of GB meomory card i could add to the camera...ive tried the 8GB but that does not work so i was wondering the max GB i could have for this camera.....also would it be okay if i used batteries that arent samsung...but regular batteries
SOURCE: Samsung s830 SDHC Problem?? Camera Dies!!
emm... I have got an 2 gb SD memorycard for mine to and it wont work. Read on several places that the camera can only handle 1 gb memory card... Dont know if that's true thou.
SOURCE: Card Locked Samsung SL 102 Camera
there is a lock button on the memory card check it if it is SD card or camera might not support the card try 1gb card
SOURCE: I have purchased a 8gb memory card for my samsung
if that happens try to reformat your sd card
all you need is a card reader and plug it in your pc find format and choose fat32*note only fat,fat16,fat32 format can be read by your camera so be careful when doing so.
SOURCE: I have a Samsung S730 digital camera and like it
Hi
The Samsung S730 digital camera will work with 2Gb Secure Digital (SD) cards without an issue. If you want to go with a higher capacity card you can also use 4Gb and 8Gb SDHC cards.
Hope this helps
David
Here is thre Samsung website to look up the technical info for you camera. Is this what you need?
http://www.samsung.com/us/support/search...
