Pride 5.5
That is fault code 131
131. (10000011) Phase 1 to 6 - Repetitive Rotor Position
Sensor Error
This fault is similar to fault number 130 above but differs slightly in that
it is a continuous condition. See fault 130 for service procedure.
130. (10000010) Phase 1 to 6 - Single Rotor Position
Sensor Error
The Motor Control Module has found an error in the pattern received
from the Rotor Position Sensor. Likely causes of this fault are a bad
connection on the harness between the Rotor Position Sensor and the
Motor Control Module, or a faulty Rotor Position Sensor.
Primary Source: Wiring.
Action: 1. Check for corrosion on the edge connector of
the Rotor Position Sensor and the Motor
Control Module connector.
2. Check the contacts on the rotor positional
sensor end of the hall harness to see if any
have been damaged. (Each set of contacts in
the socket has two wipers. If the distance
between these wipers varies between
different contacts, replace the rotor positional
sensor harness.)
Secondary Source: Rotor Position Sensor.
Action: Check the Rotor Position Sensor with an R.P.S.
tester. Replace if faulty.
Tertiary Source: Motor Control Module.
Action: Replace Motor Control Module.
