SOURCE: DMC-FZ28 camera memory
First of all, it's faster to use a fast SD to USB adapter with a fast SD card. This beats attaching a (slow) cable to the camera by far. Plus, the method of transfer gets confusing when considring internel memory via cable, on some systems. Skip the cable. I like to get my SD card with matching USB adapter. Both of these need to rated fast. Not just a "Class 6" and not just big but FAST. It saves your time! Repeatedly.
Therefore, switch to "Play" mode. Go down to the "Playback" menu and find "Copy". Copy "in" to the SD icon. That's it.
You might want to clear you internal memory too. But only after your pictures are safe.
SOURCE: SD card - memeory card parameter error
The manual for the camera states that the memory card must be formatted in the camera and that cards formatted in a computer may not work properly. Use the format command in the camera.
SOURCE: sd memory card not recognised on start up, always
obviously a contact problem. solved by pushing a piece of thick card behind the SD card .works perfectly now.
SOURCE: cannot find instuctions about formatting new SD
Select the "Format" entry from the Setup menu.
Full details are in the "About the Setup Menu" in the "Preparation" chapter of the manual (page 29 in my copy).
SOURCE: i have an sd card
With no card in the camera, go into the menu and find "format" and follow the on-screen instructions to erase the internal memory.
