Yamaha Dtxpress Iv Special Electronic Drum Set Logo
Jesse Carlson Posted on Sep 17, 2012
Dt express snare sound changes
The snare sound changes for no apparent reason. In the middle of playing, it loses the snare sound and the only way to get it back is to change kits and then to go back to the desired kit again or else I have to turn it off and then back on again. I have tried to restore the original factory settings, but it does not fix the problem. I need to understand if this is a problem with the brain, or whether it is a problem with the snare drum. Any suggestion on what needs to be done to fix this problem?
Chris McCoy
Level 1:
  • Contributor 3 Answers
  • Posted on Feb 07, 2013
Chris McCoy
Contributor
Level 1:
Answers
Questions
Helped
6234
Points
Check your snare and the red knob next to it, if you turn this knob it will turn off the snare, it could even have a short or etc.
5 Related Answers
Anonymous
  • Posted on Dec 23, 2008
SOURCE: add more paths to the drum kit
A line splitter I would asume. Some people just by two brains or more and make a really huge set. I would recomend just buying to brains, alot easyer and more options to chose from.
Michial Gueffroy
  • 1140 Answers
  • Posted on Nov 16, 2010
SOURCE: I need to reset (
Here is a link to the manual if you don't have one:http://www.dtxperience.com/documents/Manuals/DTXPRESS_IV/DTXPRESS_IV_Owners_Manual.pdf The procedure is on page 35.
Fred Yearian
  • 5603 Answers
  • Posted on Feb 24, 2011
SOURCE: um i lose power completely
Check the condition of the inout power jack and the soldering of it. Also look for cracks in the circuit board around the jack. These jacks are marginal and are often intermittent.
Fred Yearian
  • 5603 Answers
  • Posted on Mar 10, 2011
SOURCE: I'm trying to use the pads of my Yamaha DTXplorer
Actually, ONLY TWO pins are used in the MIDI cable. The data is sent serially at a 31.25KBit rate.
You probably need to "map" the ones that aren't working into the appropriate codes to trigger the SR-18 sounds.
You need to COMPARE the codes sent from the DTX to those needed by the SR-18.
There also may be options in the DTX for type of drum kit such as "Latin" and selecting one of those may have the mapping already done.
In the literature of each device will be a list of the MIDI codes the DTX generates and those required by the SR-18.
essentially the percussion codes are NOT standardized completely between devices... but there is usually a way to "map" them to make it work.
sparky1500
Matthew Spark
  • 1066 Answers
  • Posted on Mar 12, 2011
you need to determine what midi note the DTXplorer is using for the snare, kick and 3rd tom, and set the SR-18 accordingly, or vica-versa. the midi notes for each instrument has to be the same.
if you cannot change the midi note in either unit to make them correspond, you can download a "midi mapper" program (i think e-drum might be one), there is freeware available if you search CNet. with a midi mapper program, you would have to get a midi/usb adapter for your computer and rouite the midi signal through a computer. midi mapping software allows you to change the midi note, when the hardware itself is incapable of doing so.
Middle D key apparently was jarred loose in transport. It is sticking up and won't return to its original position, and playing the key produces no sound.
Call Yamaha at 714-522-9000 and ask for a tech who works in your area. Attempting self repair could void any garuntee that is covering the problem.
I have the dm10 studio pro 2011 kit, and no matter how i store settings for priority, if the rim of tom 1 or 2 are struck at the same instant as the snare head, the snare does not sound. even if i set no...
Realize first that your "instant" is like eons to the electronics where billionths of a second count... This is an interesting set of symptoms. I would connect one of the other devices to one of the tom inputs and see if the snare acts the same using that devicee. Also try to characterize how much ahead or behind the snare hit the tom hit can occur and have both sound. This problem MAY be embedded in either the electronics or the firmware in the module. It could be an electrical noise issue or any of several other things. I want you to try this using ONLY headphones and NO amp... this is to isolate the possibility that the vibrations of the snare by the amp may be triggering anti-noise gate in the snare circuit. These are some more tests I want you to do the above and give me the results.
2helpful
I have the Simmons SD9K electronic drum kit. I really love it, but I have two seperate issues. First, I sometimes get a snare pop out of the blue while playing a beat and sometimes just after I stop...
With the sensitivity set very high, you might be getting false triggers from static discharges. It sounds like your snare trigger is either bad or possibly the cable from it may have a problem as you should NOT have to set the sensitivity so high.
It will take an oscilloscope to test the pad unless you can find a system to do a sensitivity comparision. The second problem regarding the recording/overdubs I cannot help you solve.
2helpful
2answers
When I hit the snare drum harder than usual, it is making a different sound. Is that supposed to be?
I believe I have found a good part of the solution to this problem. I also had this problem in the snare. The problem was so severe that, when pulled, the snare support, without giving him any beat, the sound appeared. I took courage and opened the snare.Ao open, I realized that a yellow adhesive used to glue the trigger wire had melted and the other touching the trigger. I think this must have happened at some point prior to my purchase that equipment has been under excessive heat and then drained to such a glue. Simply cut the little wire glue "connected" two triggers, and closed the snare ....... ready: is working perfectly.
1helpful
I'm trying to use the pads of my Yamaha DTXplorer drum kit as triggers for the sounds stored on my Alesis SR-18 drum machine. I have seen that Alesis markets a trigger module of their own which they...
You can not play these drums live the spill of the fold back drum fill bin sets of the snare trigger ive turned down the sens on the red box still doesnt work a big waste of money i need to talk to...
With this kit being acoustic-electric, the only advice I can give is to disconnect your snare trigger and mic the snare. It's either that, or your snare trigger is faulty. A new trigger is going to cost about the same as mics, but mics won't hit your snare, making you sound inexperienced. For miking the snare, you'll want to get two mics, placed on the top and bottom head. Try to position them on the same spot on the rim to avoid voicing problems. Studio drummers do the same thing when recording.
For playing this way live, you'll want to use either the main PA, or run to a separate mixer so you can control the volume of the snare in relation to the rest of the kit.
Hope that helps!
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/cameron_463100ffd54b591d
Every time i hit it anywhere on the front the snares shake, whats wrong?
Absolutely NOTHING is wrong. The snare drum resonates. The only solution is to NOT let th snare drum "hear" the Cajon... This is a common problem... Other instruments can also trigger the snares... SOME people add clearance of the snares to the drum to avoid some of the problem.
Seperate tracks
They have to be recorded on SEPERATE tracks if you want to keep them seperate. It will be hard to do this live as if you mic acoustics you will still get some cross feed in the mics from the different percussions.
With an electronic drum set it may be even harder as they often only have a single mixed output.
The way the professionals would do this is to play the kick and record it on a track... and then play that track back and record the snare and hat each seperately on other tracks.
Once you have synced tracks of the parts, then you can mix anyway you want.
With electronic drums you COULD have two seperate modules to give you two seperate outputs, but that is a budget breaker.
2answers
The snare connectors on my premier snare drum are loose. how tight should they be?
It should be adjusted just tight enough so the snare doesn't rattle when it is not on.
Top Yamaha Music Experts
Paul Bade
Are you a Yamaha Music Expert? Answer questions, earn points and help others
